Toshiba Satellite C655-S5212 Laptop Logo
JOHN VANDEVELDE Posted on Apr 24, 2012
What would nail polish remover spilled on key board do
Spilled acid tone on the keyboard and computer will not sart up now, how to check what could have been damaged
The PC Clinic, LLC.
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 31 Answers
  • Posted on Apr 12, 2014
The PC Clinic, LLC.
Contributor
Level 1:
New Friend:
Cheetah:
Answers
31
Questions
Helped
1840
Points
43
Most often nothing once it has had the time to fully dry out.
Smell of methylethanoate
Also known as methyl acetate and can have a pleasant odor similar to some glues and nail polish removers. If there is much around, it is flammable, be careful with flames in the area.
tip
Carpet Stains
I have a blue rug in my living room. The other day bright green nail polish was spilled on it by our daughter.. My husband was ready to freak. I soaked the spot with nail polish remover and rubbed it with a damp rag. I then sprayed it with Woolite spot spray, rubbed in a circular motion and let dry. The rug is fine and there's no more stain.
If you pour sugar on spilled nail polish does it make it clump so it can be swept up?
can not you use nail polish remover on a cloth to wipe up the spill or is it on a material that will mark from the acetone in the nail polish remover ( Plastic bench, or other acrylic materials )
3helpful
3answers
What best flooring for kitchen large dogs
Better Ceramic Floor Tiles where can easily clean.
Superglue remove
nail polish remover painted on with a nail brush will most likely do the job. .super glue doesn't like acetone so if that doesn't work paint on acetone very carefully.
I accidentally spilled nail polish remover on my macbook. it works fine now but i've noticed the fan runs more frequently now. is this normal?
it's possible you got some inside your mac. When it heats up, can you smell the remover? It might be that it dried inside and is being reheated every time you use the mac.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
2answers
Coffee got spilled on my laptop keyboard. The laptop seems to work fine all except for the keyboard. When I push the keys, something different shows on the screen other than the letter I pushed. Like if I...
How to Fix Spilt Liquid on bda25ce.jpg?
You accidentally knocked fruit drink or a late night glass of milk on your laptop or your child spilled a good portion of milk directly into your keyboard. You hear a popping noise, the screen goes black. Water by itself is not as bad as milk or juice, both of which are corrosive/acidic, or coffee, tea, soda, etc.
First and most important -Calm Down and unplug the computer from its power source.
Disconnect it from the power cord and remove the battery. If needs, please remove the keyboard. The old adage - Water and Electricity don't mix - is quite true. For your laptop spilled water, let your laptop dry. Do not attempt to turn on the computer for at least 72 hours. Let it sit in a cool, dry place. If you disassembled the laptop, reassemble it after 72 hours have passed.
1helpful
I have a s520 wireless keyboard. What is happening is the white colored letters and numbers are wearing off, this includes the C , N, I, L, and E keys so far. I did try liquid white out. It does work...
Howdy, my daughter wears her keys bald all the time now only the repaired keys are legible. Here is what she does: She uses pen or colored nail polish and covers it with clear nail polish once it has dried. Very durable.
Regards, Farmerbear at FixYa.com
3helpful
3answers
I have droped a little amount of nail polihremover on my keyboard
If you don't want to pay for servicing, use an external flexible USB keyboard. Check it fits in the bag.
Spilled Grape Juice
To give it a good cleaning, you will need to remove the keyboard and clean anywhere you can see juice or feel stickiness. You can buy the expensive computer cleaners, but I suggest 50/50 rubbing alcohol and Q-tips. Remove the battery and C-mos battery to make sure there is absolutely no power to the machine what so ever. After cleaning inside, you will want to give it a good 24 hours to dry, ensure that there is no moisture before applying power. If the juice reached the bottom of the machine, you may need to remove the screen, split the cases, and take the motherboard out, in order to clean the bottom side of the board. If you leave juice anywhere on the board it will gum up, and the acids in the juice will corrode and detierate the circuitry on the board causing a motherboard failure. Now the keyboard, in order to thoroughly clean the keyboard, I suggest that you spray a good amount of the rubbing alcohol in the keyboard, shake it or blow it out with air, then take paper towels and daub up the rest. Repeat this two or three times, then let it dry approx 24 hours. Sometimes the keyboard won't recover after a spill and will need replaced. If it works properly, then, after using the keyboard for a while, you will notice if any of the keys are sticking. Take the sticky key or keys off and clean them individually. I know it's alot of work, but it'll teach you not to keep open drinks around your laptop. It did me, I've ruined one machine, two keyboards, and thoroughly cleaned a third very expensive machine of mine to keep it working, but I finally learned to drink from a sippy around my laptops.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
