Need at least 512mb to install DSL. System only showing 445. Bought 2 512 mb sticks. System setup shows memory channel 0 slot 0 installed memory channel 0 slot 1 not installed.
SOURCE: I HAVE EMACHINES W3502 , RECENTLY UPGRADED RAM TO
try removing one of the memory modules and then try it again.
SOURCE: Ram upgrades
Assuming the empty slots are for memory then just add the 2 new sticks to empty locations and leave the original one in place. The order shouldn't matter, just the overall combined amount. With the t4200 you should get a total spec of about 1.25gb depending on the operating system.
With the t3624 you'll have to pull the exhisting stick to free up a slot for one of your new ones. You'll have about 1.5gb once you're done with the install.Again, overall ram total is what counts, not the order.
Just play it safe and make sure you're correct on the locations and memory type/capacity. Check out Crucial.com and run a free system scan for your memory type and capacity. Belarc Advisor is a good program too. Good luck..
SOURCE: Beeping noise after installed memory on ecs motherboard L4S5MG
Some older computers, like mine, have a maximum memory they can handle. This one happens to be 1 gig, but yours may be less. Do you have an older computer? Yup, you do. As seen here, the maximum supported ram is 256. I'm sorry. Please rate.
http://www.dealtime.com/xPF-E-Machines-eMonster-500a-EMONSTER500A
Still only shows 445 mb
