While on automatic cycle the timer on our Whirlpool Duet dryer run for 5 mins from 40 mins and then the timer jumps to 26 mins. Timer works fine in manual mode.
Clean the stainless steel sensor pads located just inside the dryer door with isopropyl alcohol,these sensors register moisture in the garments and adjust drying times accordingly,when you use dryer fabric softener sheets it coats these sensors and throws the system off,make sure to shut off power to unit as this alcohol is very flammable,then leave door open to air out before re-powering up unit
SOURCE: Whirlpool Dryer LER7646EQO - Won't Start
my whirlpool electric dryer not turning,there anyone can help
SOURCE: whirlpool dryer: supreme Not heating up
Hi thanks for the question. the problem could be the thermal fuse located at the back . remove back panel. on the air duct . a small piece of plastic with 2 blue wires to it . replace the thermal fuse thanks .the appliance doc
SOURCE: Time skips from 18 minutes to 6 minutes on automatic mode
It is the moisture sensor system, it is not sensing the wet clothes. Open the door, inside you should see a part with 2 metal bars that is around 3 inches long, clean these bars with a mult purpose cleaner. Sometimes fabric softner sheets and detergent builds up on this so that the machine cannot sense the moisture. Hope this helps.
SOURCE: Whirlpool dryer WED5300VW0 runs and heats but
The timer has gone out,replace the timer with a new one.
Testimonial: "Thanks"
The model is WED9200SQ0. I have cleaned the sensor strips and I hear the beep when bridged. The automatic timer still skips.
General purpose cleaner failed but the alcohol did the trick.
Everything is back to normal.
Thanks for the help.
