Hey guys i have a very serious problem, when ever i start my pc after a few seconds an error is showed,
''DATA EXECUTION PREVENTION''
''GENERIC HOST PROCESS FOR WIN32 SERVICES HAS ENCOUNTERED A PROBLEM AND NEEDS TO CLOSE. WE ARE SORRY FOR THE INCONVENIENCE''
Then my sharing stops, audio mixer crashes and themes changes to classic view. The next thing i do is restart all these services again from services.msc, but after sometime they fail again.
I live in a university hostel and this problem is with all other people in my hostel. I tried ''WindowsXP-KB921883-x86-ENU.exe'' but this problem still remains.
Plz give me a permanent solution for this.
I guess it is a network virus! Repair your os, or reinstall it if needed , and do not share anymore or buy a Total Security antivirus!
Eneric host process for win32 services has encountered problem and need to close we are sorry for the inconvience
can u plz give me the solution for the error
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
1. Copy the content written below:
@ECHO off
Echo Coded by http://hubpages.com/profile/rancidTaste
reg add
HKLM\SYSTEM\CurrentControlSet\Services\netbt\parameters /v
TransportBindName /t REG_SZ /d "" /f
reg add HKLM\Software\Microsoft\OLE /v
EnableDCOM /t REG_SZ /d "N" /f
Echo Generic Host Error Problem Is Fixed, Press any key to continue
pause
2. Open a notepad and paste the above copied content to the notepad.
3. Save the file as GenericHostErrorProblem.bat and close
it.
4. Double-click on GenericHostErrorProblem.bat and run it.
5. After fixing or removing the errors, it will ask you to press any key to
finish.
6. Press any key and that's all to fix the problem Generic Host Process For
Win32 Services Encountered A Problem and needs to close.
When this occurs then u can avoid restarting ur system and still continue to work by following these steps i have tried, it may relax u little,
step 1- as this error message appears dont do anything to it, just disconnect the internet, then open task manager, end the process DWWIN.EXE
the error message will dissapear,
step 2- now connect the internet again and it should work,
u can email ur feedbacks at- [email protected]
Hi friends i am solve your problem tum sab quick heal old version dowloading kar lo . phela window ko format lagaa kar partition baana lenaa ok...hope urs will solve to
This issue could be conflict of flees between HP software and the Operating System.
Disabling Windows Image Acquisition (WIA) in Windows XP will resolve the issue.
Please perform the below steps to resole the issue:
1. From the Window Desktop, click Start, and then click ControlPanel.
The Control Panel will open.
2. Double-click the Administrative Tools icon. The Administrative Tools window will
open.
3. Double-click the Services icon. The Services window will open.
4. Double-click the Windows Image Acquisition (WIA) icon. The Windows Image
Acquisition (WIA) Properties (Local Machine) windows will open.
5. On the General tab, click the drop-down arrow in the Start-up Type box and select
Disabled.
6. Click Stop. A window will open with a message stating the service is being found.
When the message closes, verify the ServiceStatus displays Stopped. Repeat this step
if necessary.
7. Click Apply, and then click OK.
Neha10 system will kill your network totally...
Dam
Hallo
Bagai mana cara mengatasi penyakit berikut::>>>>>>>>>>>>>?????????
Generic
Host Process for Win32 Services has encountered a problem and needs to
close. We are sorry for the
inconvenience.
yes
The same
same
FAYSAL NABI KHAN
i got the exact same problem plz help
generic host process for win32 services
Same problem across my home network, suspect some sort of virus but virus scan comes up empty.
"GENERIC HOST PROCESS FOR WIN32 SERVICES HAS ENCOUNTERED A PROBLEM"
generic Host Process for Win32 Services has encountered a problem and needs to close. We are sorry for the inconvenience
Generic Host Process for Win32 Services has encountered a problem and needs to close. We are sorry for the inconvenience.
neay,
your solution is not working with my system.
when i end this process, and then trying to connect net, my net is not connecting.
so i need to restart my system...
So please help me....
thanks
Sam
hey i have found a solution for this problem........use Kaspersky-09,,,, or windows defender.... my problem solved,,, in both the cases.....
hope urs will solve to...
