When I flush the toliet the tank empties but will not refill. I can remove the lid to the tank and pull up on the float and it will begin to fill back up like it is suppose to. However, when I flush the toliet again it will do the same thing. What should I do?
The toliet tank won't refill after flushing. it has been freezing outside could the water pipe to the tank be frozen if so how could i fix this problem
Okay depending on the type of toilet ball **** (i know its a funny word, but it's really what its called.) you have one the most standard type is the long wire with the big ball on the end. you need to adjust this ball **** so it goes lower test it out, flush your toilett and wait till the water drains then when its supposed to come back up push down on the ball **** and youll see the water will start to fill, so then adjust the little screw on the fill valve (the other side of the floater where its attached)
you may need to shut off your water supply and drain your tank depending on how skilled you are,
pretty simple work, if you have questions feel free to ask.
I have a similar problem with the tank not filling after flushing, but I have float cup type system. And I tried to manual move the cup up and down and still no water flows into the tank. It is freezing outside and my home was built in 2004 with no exposed plumbing on the outside. Could the pipe to the toilet be frozen so no water is getting into the 2nd story toilet? All the other plumbing in the house works. Can you help me?
