How do you take off the hook riccar # part from the sewing machine?
Today I got such a machine (Riccar) for free from a lady I know. the only problem was that the needle walked against the bobbin (timing problem).
I screwed the sewingmachine open and after some screwing I saw that the part, Hook Drive Gear, Riccar #53741, was broken. Wat I did is I enscrewed two screws wich hold the part on the axe and with a bigger flat screwdriver I could just push the part from the axe, from the other gear. It looks more difficault then it is.
Now I have to get a new part, put it back and time the the machine so that the needle will go normal, at the right time, in the bobbin. Does anybody know the trick to do that?
regards,
Daan
SOURCE: riccar sewing machine 8500
I don't know if this will help or not, but here is a website where you can download a manual for any of the Riccar products: http://www.riccar.com/help/manuals/
SOURCE: Hello I have an old Riccar 6800 sewing machine
Hiya, the threading for this machine is pretty standard so you won't be going wrong there. Have you used a sewing machine before? The tension dial (on the extreme left) should be set at 5. The other dial to your left should be on blue zigzag with orange broken line. The dial on the right should be set at 0 and the bottom one on 2 - 3. I've been looking for a manual for this machine as I inherited this one. It took me ages to suss straight sewing out. Another thought is take it to a repairer and ask for a quote. Good luck.
SOURCE: Need instruction manual for Riccar 888.
Found the instruction booklet to my machine, and ordered it.
SOURCE: Looking for Riccar sewing machine manual
you can get the manual by goggling Riccar 1570 manual for free. It will download, no problem
SOURCE: I have a riccar 9900 electric sewing machine. I wa...
this might work. i have the same machine and use metal bobbins
http://www.vacsew.com/bobbin-2518-j.html
