My hard drive stopped working after my laptop ran out of battery during a data transfer. at first it just didnt open and asked to be formated. off course that was a big no-no so i disconnected it and tried to open it again. thats when it stopped being recognized but the weird thing is that the "cd drive" that comes in it for encryption is still appearing when i connect the drive. it doesnt work either though. i just want my files i have in there, how do i get them ???
SOURCE: WD My Book Essential keeps asking me to format
There are two main reasons why this could be happening. Vista will ask you to scan/format any portable or flash drive the first time you plug it in as it prefers you use it's newer version of NTFS but it's not required. If this is the case there is an option on that pop-up window to continue without repairing the drive and it will work fine once you select that.
The other major possibility is that the drive was active at the time of the crash and that the file tables were damaged at that time. If this is the case your file are almost always still there but windows hasn't a clue where to find them, it's like somebody shot the librarian and you don't know the name of the book you want.
If it is the second problem you have a couple options depending on how bad the damage is.
1. Try the program"Get My Data Back" it's a bit amateurish but works well on deleted files and minor drive damage.
2. Send your drive to a pro(try one first if you like), there are a few good places in North America that offer cost effective recoveries on minor problems like this generally $100-$200, but it can be more if the damage is more extensive. Armor-IT Data Recovery has adverts in each US state and can be search in FixYa's Database, or on Google if option one doesn't work.
Hope this helps FixYa
Chris
SOURCE: computer doesnt read the external hard drive anymore
It sounds like the hard drive head crashed when you pulled the power plug. Unfortunately if you can't get drive to be recognized, you won't even be able to run any diagnostics. You will have to take the drive to an authorized repair shop who will have to check the electronics to see if the head will respond. Unless you have data on your drive that you absolutely need, you will probably save a lot of money by replacing rather than repairing the drive.
SOURCE: Vista stops recognizing external hard drive
This doesn't sound like an OS issue. This appears to be more an issue of the connection to the hard drive. The USB cable likely isn't the culprit, nor the laptop USB inputs. If the drive was ever dropped or the cable gets removed and reattached often to the actual enclosure, you might be looking at a bad port on the enclosure. This isnt a lost cause. You can always buy a hard drive enclosure from newegg and move the drive from the IOMEGA to the new enclosure. You can get a new enclosure for $15. Just because the USB port is bad, it doesnt mean the data is gone and the hard drive cant be used.
SOURCE: my iomega 500gb external hard disk is corrupted
my pc is not showing my 500gb iomega external at all,in device manager syas all is working correctly
SOURCE: Suddenly my Iomega 1tb stopped working and i
Have you tryed chkdsk in the command prompt, goto command prompt and type CHKDSK F: /F and press enter, this is a tool that checks your drives for any errors and hopfully should resolve any problems, rather than formating it and loosing everything on the drive.
Also have you tryed setting up the usb for mass storage in the bios somtimes there is a setting for this in the bios, or try setiing it back to factory defaults and see if that works.
The only other option would be to update your usb 2.0 driver in device manager in the properties of my computer icon on the desktop. hope this helps in some way and post back what happens.
