Question about Behringer Eurorack Ub802 - Ultra Low-Noise Design 8-Input 2-Bus Mixer
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
    New Friend:
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Posted on May 21, 2015
5 Suggested Answers
SOURCE:
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: LEVEL POT ON A BEHRINGER EURORACK MX 602A-BAD
It appears that both these use a 50K pot in the identical circuit and it is UNLIKELY they re-engineered very much so it is likely they use the same pot.
Behringer parts service should be able to tell you.
Posted on Apr 28, 2010
  • 5603 Answers
SOURCE: behringer ub802 mixer is buzzing
If it buzzes when you have no inputs AND no output leads connected, there is a problem with the power supply... HOWEVER if you have used UNBALANCED output cables instead of the REQUIRED TRS BALANCED output cables, it is possible the noise is being driven backwards and that is what you are hearing. Note that at full gains, there often is a tiny bit of noise, usually hiss. Also make sure the supply is powered from the SAME receptacle as the equipment this drives such as an amp or powered speakers.
Posted on Jul 19, 2011
mrwtech727
  • 75 Answers
SOURCE: My Behringer mixer Eurorack UB802
Here's the manual. page 8 Good Luck!
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000064843.pdf
Posted on Sep 03, 2011
How to use the behringer 802 mixer and connect it to the computer
There are a variety of ways to accomplish this, but the two most common ways are:
  1. Purchase a BEHRINGER USB interface -- like a U-CONTROL UCA222. This will allow you to use the USB port for your sound In/Out. This will also require RCA cables to connect from mixer to UCA222 unit.
  2. Or...purchase a dedicated sound card (preferred) like an M-Audio Audiophile 2496 that can be installed in your computer (not for laptop). You will also need I/O RCA cables to connect.
Dec 26, 2014 | Behringer Eurorack Ub802 - Ultra Low-Noise...
How do you set up for a simple pa system?
It Depends how many Channels you are wanting for a basic 2 deck set up using Cdj's you would want 4 channel 2 per deck 1 master out and 1 booth so you can hear it through your head phones but if you were doing Karaoke you would want 6 channels for 2 microphones all going 2 the master out. but it changes again if us software and controller because most software has an internal and external mix mode. Here is a video that might help
Sep 02, 2014 | Behringer EURORACK UB2442FX PRO Mixer
Please can you tell me the difference?
The microphone preamps are different. The Xenyx has lower noise mic preamps.
Nov 04, 2013 | Behringer Eurorack Ub802 - Ultra Low-Noise...
How to remove white noise in my ub802
It can be a number of things.
Bad ground, excess gain, excess number of mixer channels with no inputs, Make sure the mixer inputs you are going to use are the only ones that are up. Power supply noise- flourescent lighting noise, Clamp on ferrites on the power cords of everything can help reduce this. You can sometimes track the offending source with a battery powered AM/MW radio.
It can also be caused by going from a balanced output to an unbalanced input with some impedance differences.
Feb 07, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Behringer ub802 mixer is buzzing even when no input when i hook my head phones into the headphone jack and main output jack
Jul 18, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Can't get cd player to work in my ub802 mixer.what am I doing wrong.I have connected it via RCA cable from cd player to mixer tape in .is this correct.I also have the mixer in tape out and phantom...
Phantom should ONLY be on if using CONDENSER mics or a DI box requiring phantom power... yours should be OFF. cables should be correct. The 2 Trk to mix button should be down.
Jul 04, 2011 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Need to connect to a sound blaster live sound card for recording using sonar as recording program. hace had it in storage for sometime and can't remember what went where
This particular mixer offers a usb (2 channel connection) that can be simply plugged into the computer usb 2.0. These channels should be available in Sonar from the channel Input/output drop boxes. You may need to restart Sonar, the mixer or both for them to be recognized. You may also need to run the Wav Profiler in Sonar. Typically the Wave Profiler is found in the Options>Audio menu but may be different on each edition of Sonar. The above info is for Sonar 7.
If you are wanting to record several channels at once then I would recommend connecting your Mixer's Direct Outputs from each channel to a corresponding input of the soundblaster if your soundblaster supports multiple channels. And then use the usb outbut from the Sonar to monitor the computer playback of your master stereo channel. Or, you may connect the soundblaster outputs to unused channels of the mixer or to the tape return or auxilary inputs to monitor the computer playback on the mixer.
Alternately you can send the signal to your soundblaster via the buss outputs. This will limit the number of simaltanious output channels to the number of busses on the mixer, but you can send any mixer channel to any buss without unplugging the instruments or mics.
Here's the link to the page where you can download the free pdf manual for this mixer. Page 14 explains the output connections and has diagrams.
http://www.behringer.com/EN/Products/2442FX.aspx
Oct 09, 2010 | Behringer XENYX 2442FX Mixer
Apr 28, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer Eurorack Ub802 - Ultra Low-Noise Design 8-Input 2-Bus Mixer Logo
165 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
