Replaced cyan toner. Printer said "be prepared to have magneta and yellow cartridge. Toner is low". I went ahead to replace magneta and yellow. Then the message "Print unable 25 - Troubleshooting and routine maintenance chapter in user's guide". How can I reset the error message? Thanks.
SOURCE: brother MFC 9420cn "unable to print see troubleshooting...users guide"
ctstore,
Your unit requires replacement of its maintenance kit. You will not be able to do this by yourself unless your are a technician, which I assume you are not. The cost for this repair will not be cheap, you are going to be up for over $500 and you need to do it through a brother warranty service centre.
Gremlin11
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
SOURCE: unable to print See Troubleshooting and routine maintenance chapt
Open the top cover and hold the interlock switch on the top right hand corner. Power up and wait for the carriage to come to the center. Shine a flashlight all the way to the right and left and pull out the crumpled paper. You should be able to print again..
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
All the best
