SOURCE: i have Toshiba 14" Satellite L645 i5450 notebook
the Satellite L645 line has optional built in analog modem
but can not find info on you specific model
this line does not seem to have a serial port nor pc card slot
therefore can not support a analog model unless you can find a manufacturer of a usb model
but if your want to connect to a dsl or cable modem that is done thru your rj45 port with a ethernet cable
It is possible to connect a modem to the laptop. Connect the modem to the laptop using the telephone style socket on the laptop. The mother board will then pick this up and load the relevant drivers for your modem.
If you are not sure, contact Toshiba online. They are extremely helpfull.
Hope this helps.
Test all leads that attach to your hard drive including electrical extensions EIDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure dust free connections and are not faulty or just replace them they might be faulty
you might have a dirty graphics card if you remove your graphics card clean both card and socket restart your computer then reinstall it this should activate found new hardware wizard
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
if your computer came with a motherboard disc the drivers could be on it
or you might try these
http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performance
hope this helps
