Question about Spectroniq PDV-70X
Spectroniq DVD Recorder SDR-205 Disks do not play with proper col
When I put in a comercial DVD to watch a movie the red color was missing, thus people had gray skin, and the predominate colors I saw were gray, yellow and blue. When I put the same disk in the DVD player in my computer the colors were fine. The colors on are TV are perfect, as long as we are not trying to watch a DVD. What's the problem? I hope you can help.
Carol
    New Friend:
    Problem Solver:
The remote control doesn't work with new batteries
Posted on Nov 29, 2010
SOURCE:
Samsung HL61A skin color is green
Need complete model #--to determie if this set uses an LED light source--if so--the red and blue LED';s have failed.
Mar 13, 2014 | Samsung HL61A750A 61" HDTV
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
Color problems. last night instantly the color
2 things the cable could be faulty (unlikley)but worth a try
or your lamp is starting to fail
Jun 26, 2010 | Mitsubishi WS-55315 55" Rear Projection...
Movie has no red color only green and yellow
Remove & re-seat the component video cables at both the TV and the DVD player.
If the problem continues, disconnect BOTH ends of the BLUE cable and the RED cable. Connect the BLUE cable to the RED jack at both the DVD and TV, and connect the RED cable to the BLUE jack ob both the TV and DVD. If the RED color comes back and the BLUE is missing, then replace the RED cable (the red cable is broken and will not pass the signal that it is connected to).
If all works, reconnect the colored cables to the corresponding colored jacks at both the TV and DVD player.
If the RED color still won't display, isolate the trouble to either the DVD player or TV by connecting the DVD to another TV w/ component jacks. If the RED is still missing, it is a problem inside the DVD player - if the RED displays, it is a problem with the TV.
Sep 30, 2009 | Sony DVP-NS501P Progressive-Scan DVD/CD...
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Dvd color is off
Depending on how it is configured to your TV it could be high contrast with the TV. One thing you might want to try is replacing the video cable if you have a spare. If you are using an RF modulator and watch DVDs on Channel 3, you might want to replace the coax line between the box and the TV set.
Jun 29, 2008 | Panasonic DVD-S35 DVD Player
I have a samsung sp42q2hl, which on the front of the tv say's it is a hdtv ready, and yet i cannot watch high defenition images or movies, also there is no hdmi inlet at the back so i'm not sure how you...
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
Color problem
CONNECT YOUR DVD PLAYER TO SOME OTHER TV .IF THE COLORS ARE OK ,THEN YOUR TV IS AT FAULT .
THE COLORS OF YOUR TV CAN EASILY BE RE ADJUSTED BY A TV SERVICE MAN.
THE CORRECT RATIO OF RED ,GREEN ,BLUE NEEDS TO BE ADJUSTED .
Jun 02, 2008 | Sanyo DVW-6000 DVD Player/VCR
Sharp Aquos Color Variations
Put the OPC off and check the conection for Pb signal.
Nov 13, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Spectroniq PDV-70X Logo
373 people viewed this question
Top Spectroniq Televison & Video Experts
Ekse
Jayesh Panchal
Jayesh Panchal
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
