Refrigerators Logo
A
Anonymous Posted on Apr 22, 2012
Hitachi fridge water dispenser - Hitachi Refrigerators
2 Related Answers
Anonymous
  • 132 Answers
  • Posted on Aug 15, 2008
SOURCE: water dispenser inside fridge does not dispense water
Are the water inlet / outlet correctly fitted onto the filter ??
Sounds silly - but very easy mistake seen several times.
Is the water supply for the filter turned on . . remove hoses from filter to verify. - YOU WILL GET WET.
Anonymous
  • 72 Answers
  • Posted on Jun 15, 2009
SOURCE: Maytag side by side fridge...water dispenser problem
If the water is visible in the front, more than likely the hose has become disconnected from the door, if you look at the lower left hand corner you should see the hose come from underneath the machine and attach to the door via a plastic quick connect, it is just a push lock connection. You may have to pull of the toe kick and the left hand end cap depending on the model to see this.
Lg fridge lmx 25984 no ice and no water. if I power off the unit for a few minutes and turn it back on I will get water thru the dispenser but only for a minute or 2 then the water shuts off.
Did your fridge come with a dummy or fake filter? If so put that in and see if it will dispense. It may be that the fridge software is preventing the ice maker and water dispenser from working until the filter is replaced. Some GE fridges actively prevent bypassing the filter.
1helpful
No Water going in to the fridge
Hi Norm,
Most fridges don't need a motor to run in order to dispense water. A simple on / off solenoid on the water line (same for the ice maker) that makes a click when changing from off to on and on to off is usually all anyone hears (the ice maker makes rumbling sounds and you can hear ice falling into the bin - too).
Check for ice. If it has a maker and it is making ice, the problem could be a defective water dispenser switch, solenoid or other circuit component or wire. If no ice, I'd suspect a filter or water supply issue.
Make sure the filter is fully inserted and twisted into place. Many filters have marks to align when 1) inserting and 2) to let you know when it is installed correctly. When sure it is installed correctly - try to dispense water again. Many fridges will dispense water without a filter. Check your manual before trying this though! If not working still, remove the filter and try to dispense water. If you're able to dispense water, the problem is either the installation of the filter or the filter itself. Try to re-install it correctly. Try to dispense water again.
If it still doesn't work - call the plumber back and ask why there's no water. Or - try this yourself:
Locate the point of attachment to the domestic water supply that the plumber used. There should be a valve to turn the water on and off. If off, turn ON. Try to dispense water again.
If that doesn't work - check to see if the fridge has pinched, kinked or crushed the water supply line. You may need to move the fridge forward to gain access to the water line and connection point on the fridge. Repair or replace the line as needed and route in such a way that moving the fridge in or out will not cause it to damage the line again.
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Fridge will only dispense 6 cups at a time?
Some fridges have a safety feature built in, which turns off water if the water valve was open for a certain number of seconds, to avoid flooding. So if you need a lot of water, make sure to release water dispenser lever for a second or two every minute.
If the above is not the case, you may need to replace the water valve or a switch on the water dispenser.
The way to find out which part needs replacement is to check the voltage on the green water valve coil when the dispenser lever is pressed but it's not dispensing water. If 110v AC is present across the coil - replace valve. If there's no 100v AC - replace switch in the dispenser. Make sure to unplug the fridge before opening the dispenser.
Vlad
First Choice Appliance
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
1helpful
2answers
Water dispenser not working
I have a Hitachi R-M800GM.
When i operate the water dispenser, water flows out from the dispenser [not strong flow]. There is also water flowing out at the bottom of the freezer door [hinge area]
I think the line running inside the freezer door may have come loose? If so, how to reattach it? Do u have any layout drawings of how the hose is being connected.
Please help.
Thanks,
Rick
3answers
Water dispenser inside fridge does not dispense water
2answers
Whirlpool water dispenser
IS THE FRIDGE OMPARTMENT COLD ENOUGH AS THE TANK THAT HOLDS THE WATER IS LOCATED IN THE FRIDGE COMPARTMENT.PLEASE FEEL FREE TO ASK MORE ADVICE.MOHAMED
Top Hitachi Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Hitachi Refrigerator Expert? Answer questions, earn points and help others
