1. Remove the toe grille. 2. Remove top hinge cover if available. Trace around the hinge with a soft lead pencil. This makes the re-installation easier. Remove top hinge and lift door off the center hinge pin, and set the door aside. 3. Unscrew the center hinge pin using an adjustable wrench and save for reassembly. Ensure that the plastic washer stays on hinge pin. 4. Lift the refrigerator door off of the bottom hinge and set aside. 5. Remove center hinge and shim by removing inside screw and loosening two outside screws enough to allow hinge and shim to slide out. Tighten screws. 6. Loosen two outside screws on opposite side of refrigerator, remove inside screw and install center hinge. 7. Remove two screws on bottom hinge with 3/8" socket wrench. 8. Install bottom hinge on opposite side with the two screws removed from Step 7. 9. Unscrew the bottom hinge pin using adjustable wrench. Move hinge pin to other hold in hinge and tighten with adjustable wrench. 10. Reverse door handles. 11. Move freezer and refrigerator door stops to opposite side. Before starting screws, use an awl to puncture the foam. 12. Position refrigerator door onto bottom hinge pin and screw center hinge pin through center hinge into the top of the door. Close refrigerator door to help align hinge hole. 13. Tighten center hinge pin with adjustable wrench. 14. Remove cabinet and hinge hold plugs and move to opposite side. 15. Lower freezer door onto center hinge pin (if you have a separate freezer door). 16. Close freezer door. Have an assistant lift up on opposite side of the door while tightening screws to install top hinge. 17. Flip top grille and reinstall. 18. Plug in electrical power cord and turn refrigerator temperature control to center position. Adjust setting as needed.
I see that you are trying to remove the doors on your Frigidaire refrigerator, model# FRS23R4A, for shipping purposes. Below are the instructions you will need to follow for both the refrigerator and freezer doors.
DOOR REMOVAL INSTRUCTIONS:
If it is necessary to move the refrigerator through narrow doorways, follow these steps to remove the doors.
IMPORTANT: Before you begin, turn your freezer and fresh food controls to "O" and remove electrical power cord from the wall outlet. Remove any food from the door shelves.
1. Disconnect electrical supply.
2. Open both doors, then remove toe grille.
3. Close doors.
To Remove Refrigerator Door:
1. Remove top hinge cover screw on refrigerator door and remove cover.
2. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
3. Remove top hinge and lift refrigerator door off bottom hinge pin. Set door aside.
4. Remove bottom hinge, if necessary.
5. Reverse this procedure to reinstall refrigerator door.
To Remove Freezer Door:
1. Disconnect water line coming from lower hinge of freezer door at connection located under front of freezer: Press outer ring against face of fitting, then pull to remove tube.
2. Remove top hinge cover screw on freezer door and remove cover.
3. Disconnect wiring harness connector plug at top hinge: place your thumbs on flat sides of each connector and bend both parts back and forth, then with firm grasp, pull both pieces apart.
4. Trace around hinge with soft lead pencil. This will make it easier to realign doors when they are replaced.
5. Remove top hinge, allowing wiring harness to pull through hinge and lift freezer door off of bottom hinge pin. Lay door down flat to avoid kinking water line.
6. Remove bottom hinge, if necessary.
7. Reverse this procedure to reinstall freezer door.
When both doors have been reinstalled, connect water line by inserting tube and push until mark touches face of fitting, replace toe grille and plug in electrical power cord. Turn both temperature controls to center position. Adjust settings as necessary. Hope this is helpful.
Hi Mel, I looked for a manual for your fridge but couldnt find one. These jobs are pretty similar - regardless of brand however.
You should first deremine if your model does indeed support swapping the hardware to allow the door to swing the other direction. Look at the points of attachement for the handles and hinges on the door and the fridge body itself. There are typoically pre drilled holes for fasteners in these parts on the opposite side - but have plugs or covers over them to minimize their appearance. if you have these tell tale indicators present - you're good to go.
The process will require removal of all products stored on the doors of the fridge and freezer compartments, and placing in a thermal container or cooler.
The hinges consist of one at the top, one at the bottom and usually one in the center that engages both the bottom of the top door and the top of the bottom door.
At the top, you may need to remove a bezel or cover to gain access to the fastener head(s). Many times these are hex head screws, but could be any type really. Two, 3 or more fasteners may be used to hold the top inge to the fridge. Once the screws are loosened / removed the tops door will shift - so be ready for it (or have afriend support it while you remove the fasteners). The doors are surprisingly light - a thein meta outer jacket wrapped around a lightweight drame, lots of insulation and plastic is it really is. Lift the top door up and away from the center hinge pin. You may find one or more spacers or washers made of metal or more likely - nylon. Remove these and set aside as they will likely be needed to put back in place when the hardware is reversed.
The lower door is being help by the center and bottom hinges now. You should have access to fasteners holding the center hinge to the fridge. Support the bottom door as you loosened and remove the fasteners on the center hinge If you are unable to access the fasteners of the center hinge, try the fasteners on bottom hinge instead. If you get the center hinge loosened, you should be able to lift on the door slightly to roll it out from between the center and bottom hinge. otherwise, when the bottom hinge fasteners are removed, the door will drop and be free from the fridge. Look for similar spacers or washers on the bottom hinge pin that yuou found on the top of the center hinge pin and save them.
Remove any remaining hinges from the fridge.
Remove door handle hardware from both doors and remove plugs / covers from the opposite side of the doors. Secure the door handles to the otherside and insert the plugs and covers into the holes that had previously been used to fasten the handles.
Remove the covers / plugs from the fridge and insert into the opening that previously fastened the hinges to the fridge. Swap any covers / plugs on the doors for hinges if needed.
Reinstall the hinges and doors in reverse order of removal. If the bottom hinge was last to come off - it is first to go on. Reinstall the spacers on the pin. The bottom door is placed on the bottom hinge pin. Place the center hinge pin into the recess of the top door and secure the hinge to the fridge. Place the spacers over the top pin of the center hinge. Place the top door recess over the center hing pin. Align the top hinge with the recess on the top of the door and insret fasteners through top hinge into fridge. Hand tighten all fasteners. Operate doors and check for rubbing, binding, etc. Adjust number and location of spacers as needed to allow doors to swing without scraping or binding. Once satisifed, tighten all fasteners. Adjust feet of fridge as need to allow the doors to close by themselves if left open by accident. Restock fridge & freezer.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips. Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
assist in closing the door. If it’s wore out and doesn’t work the door may not
door in place. Put something between the bottom of the doorand the floor to hold it in case it slips.
Have you looked at the mounting bracket for the lower hinge to see if it can be adjusted up. If not and there is as mush as 1/4 to 1/2" adjustment i suggest that you get a spacer with the inside diameter the same as the hinge pin or a tiny bit bigger and cut it to the size you need , then support the door up to a point that the bottom pin is not bound, remove the lower bracket and hinge pin, put the sleeve you cut on the hinge pin and reinstall the bracket.
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
