Tv was working ok . I pressed the remote pwr off.next am pwr on . does not turn on . standby blinks 2 times.
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
SOURCE: sony trinitron wega 36 inch
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
SOURCE: Sony KV36XBR800 standby blinks 4 times
The 4 blinks usually mans that there is no vertical deflection signal. Look for a small flat Ic with about 11 pins that may be marked LA7837 or something similar. Resolder the pins on that first. If that fails to resolve it, replace the IC.
Keep me posted.
Dan
SOURCE: Sony KV36XBR800 standby blinks 6 times no picture
my 36" sony trintron won't come on this morning. it is an 02. no picture or sound. standby blinks 6 times. had problem about 3 years ago and had to take to repairman. any ideas
SOURCE: I have a kv-32ls60u Sony TV. It blinks 5 times
The most common failures are the flyback transformer assembly and sometimes some of its support components, and or there is the possibility of a short in the CRT electron gun. In either case, the power supply is going in to protect mode, and the uPC is sending this flashing error code to the front LED.
I have no idea if the flyback transformer assembly is still available, but I am very sure the CRT is no longer available. In any case you will find the cost of servicing your set to be expensive for its age. The last time I checked, the cost of the CRT exceeded the replacement cost of the set.
Jerry G.
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
