insert original win installation cd and reboot... when in boot mode make sure you are booting from CD, not from disk, when message asking that you "boot up from cd " appears, just press any key, and folow procedure, but do not install a new copy of windows ! There must be "repair your computer" option on your CD, for Win Xp - it is "recovery console" ! When repairing finishes restart computer and boot from disk (just do not press anything when you see message "boot from CD..." and let windows from HDD configure it self).
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
hi
You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password
when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
"Windows could not start because the following file is missing or corrupt: <Windows root>\system32\hal.dll. Please re-install a copy of the above file."
"<Winnt_root>\System32\Hal.dll missing or corrupt: Please re-install a copy of the above file."
"Cannot find \Windows\System32\hal.dll"
"Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears.
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Please let me know you have any further questions or concerns.
Thanks.
Is this XP?
Do you have the XP cd or the recovery cd's. This needs to be fixed by performing a Windows repair. missing or corrupt: \windows\system32\config\system"means that the OS,XP, is missing an essential file to run.
Or it could mean that your hard drive is failing. Is the hard drive noisey?
Leave me a comment,here
this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work. When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
