Hi experts. I have bought a sony ericsson usb data cable with a mini cd included which contained the driver files. I have a toshiba A200-29j laptop. The dvd drive is not designed for mini disc but the first day i inserted the disc into the pc it took about 7-10mins for the dvd drive to read the cd. Now the dvd drive cant read the cd. I inserted the disc about 30 mins the dvd drive auto-ejects and a window appears telling me to insert a cd whiles the mini cd is inserted.please tell me how to insert the mini cd correctly. Thanks in advance
SOURCE: Laptop CD/DVD drive won't detect CDs but will detect DVDs
sure..go to my computer..and see what disks are there?
if there are none, go to control panel, system device manager, and look at dvd drives and see that there is no marks on it(meaning that it's installed)
if not, remove that drive, click on actions/scan for hardware change, and go
you may need the install vista disk to make that happen, but that's unusual.
check for printer drivers here
SOURCE: hp Pavilion dv6000's dvd-rw won't work
Hi, i use an HP pavillion dv6000 with Optiarc dvd rw ad -7561a ata (light scribe). i tried installing a softwear after which my dvd rom will not work it was complaining of driver corruption. i did uninstall and re- installed th driver from the system hard drive. but it will not install correctly. my computer can also not read drive E anymore. can some one help please.
SOURCE: Toshiba Satellite M45-S359 Laptop CD/DVD drive keeps ejecting!
pull your driver from laptop ther eis 1 lock open it.
and if problem still then your lense has some problem u have to clean it or give for replace or repair shop
You do need to take out the high and low filter in the string in the registry. Also remove the same filters w/ a .bak extension. I own a large computer business and we see this almost daily in XP and up.
SOURCE: dvd drive wont eject the dvd.
find a thin stick but must be verry thin. you will see a small hole in DVD uniit. put the stick in it your dvd will eject.
i tried that about five times. The drive can take any cd but not mini cd's. Thanks for your great suggestion
