Filled with water then just a humming &clicking sound, no agitate, tries to run it on spin & no spin either
The starting capacitor is bad or the belt broke, worst case the transmission is damaged.
Pull the cover and see if the belt is attached, if it is and the motor is still humming the start capacitor is bad.
If either of the 2 solution's aren't the solve for this then more then likely the transmission is locked.
If you are good with reading numbers off electrical components replace the cap yourself, it should be just 2 wires and remember to UNPLUG the washer before removing this item as it could be live at the time of removal and it could put you out cold or kill you.
If there is more then one wire located on the cap take a picture of where the wires go with a camera phone or digital camera as that schematics can be a pain to read unless you are familiar with them
Sounds like you got current, but it won't engage.....the belt could have come off
SOURCE: My washer does not wash the clothes or go through the spin cycle.
It sound like a belt problem. Try to move tub manually first, in case it move smoothly -open the front panel, the belt should be between the motor and the drive pulley (lower front). In case it torn or not in its place, you should replace it. In case it doesn't move smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, it should be removed. Good luck !!
SOURCE: will not agitate,spin or drain
There's a coupler that normaly goes.just tip the machine over and loosen the motor.the coupler will be 3 legged and plastic.just replace and it should be ok.
SOURCE: Washer Not working please help
sounds like the motor is out or goin out.........or maybe the belt is stretched
SOURCE: will fill water but agitator wont run.
you have a broken motor coupling if you want to tackle this your self then reply to this message and i will tell you how if you have to rate me to reply then give me 4boxes im not sure how this site works you can do it if you like to tinker
SOURCE: Washing machine won't spin or agitate
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For
safety, washing machines are made so that they spin only with the lid
closed. The lid switch prevents the spinning action when the lid is up.
