Whirlpool 21.2 cu.ft. top freezer-refrigerator.model wrt771reyb. looked at this at menards . on line doors open from left to right. can this refrigerator be puchased with doors opening from right to left
SOURCE: Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
SOURCE: Reversing doors on Roper Refrigerator
If the door is reversible you will see plugs on the opposite side and top . pull out the plugs and save . remove handles and hinges and move use plugs on other side
SOURCE: French door refrig..right door pops open when left door is closed
remove the door and check the closer inside the door @ the bottom . it is a cam that helps close the door and it is probably broken part # 67002732. this was the problem with my maytag fridge-- 3 visits from A& E could not solve the problem. hope this helps
SOURCE: Left door open on Sub zero model 650
It went into self protection mode. Just leave it closed and when the compressor cools down enough, it will start. Once the ref starts to cool, the lights and such will come back on.
All of this assumes that no failure was caused by the long run times when the door was open
