The sensing light comes on. the lid locks. It tries to start then nothing happens. the lid lock light then flashes and nothing happens. You cannot open lid. If you hold button a long time (more than the 3 sec recommended) eventually it will clear but the problem repeats. I tried various settings, even unplugging but no change
You need to get into diagnostic mode and check the error codes. This washer will give you couple of error codes but the first one is the latest. To check error codes
How to Read Vertical Modular Washer VMW Error Code Display
Calibrate/reset error
How to Calibrate Top Load Washer
After calibration/resetting the codes, check error code again that will give you correct error code. If there's no error possible problem is the actuator.
SOURCE: Control Lock light is on. Cannot get it off. cannot run washer
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
SOURCE: Washer won't start/lights on
ok try first to make sure the detergent drawer is closed tight if its not will stop washer is the door locked some times you have to close them firmly make sure the lock light is on hit pause cancel twice then try washer
SOURCE: control lock light on-door opens-won't start
Press 'control' + 'pause:lock' +
'temperature' for 5 seconds
OR
'end of cycle' for 5 seconds. Tell me which worked & rate me pl.
