Need wiring diagram for deckhand anchor lift. only have serial # to identify product with
SOURCE: Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
SOURCE: What spec battery is the
that depends on the usage you want. any good deep cycle marine battery should do you good. min of 700 cca
SOURCE: my minn kota endura 55
I had this problem with my MinnKota Endura 35. The gear teeth that turn the prop are off center and need to be realigned. You need to take it to a service depot as trying to open the casing yourself may do more damage. Plus when it it put back together you need to ensure that it is water tight again.
Cost me around $85 at the local marine mechanic...
SOURCE: My minn Kota deackhand 35 won't lift a 28lb anchor
How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
