Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
Tray empty message
Jura Capresso Impressa  z5---We keep getting a "Tray Empty" message on our machine. We can remove the tray, put it back in, get "Coffee Ready" and then when we put a cup under the nozzle, we get a "Tray Empty" message again. Is there a sensor somewhere that's goofy?
  • 1 more comment
  • pwoodsmall Nov 24, 2008
    Same problem exactly. I have also unplugged the machine, run the rinse cycle a couple of times, etc. Tried cleaning the machine but I can never get past the "Grounds Empty" stage.
  • BobPR Nov 24, 2008
    I have a similar problem with machines in two different houses. My owners manuals do not state how to clean the contacts. Any ideas?
  • Patrick Whittemore
    Patrick Whittemore Dec 29, 2016
    I had a sticky film on the contacts from the tablet when i had a issue cleaning it.. I rinsed the contacts with water and dryed them off with a towel and had to cycle the power.. Wasted a Pill -.-
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
  • Dany DiLullo
    Dany DiLullo Aug 05, 2016
    I had the same problem. I tried cleaning the contacts with a nail file to no effect. However, when I pried the 'female' contacts up with a file so as to create a more positive contact with the contacts of the tray, the problem was resolved.
  • 3 Answers
What i do it put paper towel on the metal contacts, put the tray back in to the machine with the paper towel on it and then pull it back out.  The paper towel will clean the slot inside the machine.
Posted on Dec 09, 2008
  • Michael Krasow
    Michael Krasow Jun 15, 2017
    Worked perfectly thanks
According to the Instruction Manual section 21 page 68 when this happens it is because there is a "solied metal contact at rear of drip tray" and you need to clean the metal contacts.
Hope this helps
Posted on Nov 22, 2008
Oilerfan's paper towel trick worked fine for me. WARNING : use only one layer thick. If you use two layers or more, the tray may become stuck by the metal contacts. You will need to use much more force than wise or safe.
Posted on Feb 14, 2009
Or you can just cut a piece of card to the width of one of the contact slots and fold kitchen paper over that - worked fine
Posted on Sep 13, 2009
SOURCE:
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
Mar 08, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Tray empty message will not dissapere
i had this same problem, just unplug the maker and plug it back in then open the tray and close it. that should fix it
Sep 15, 2012 | Jura Capresso Impressa Z5 Espresso/Coffee...
I can't get the tray back in
Remove the grinds container than put it in, rinse or power cycle the machine and it will be sorted out.
Sep 03, 2012 | Jura Capresso Impressa Z5 Espresso/Coffee...
Took the tray out to empty it, put it back in but now it says tray empty and won't work
Check the two contacts at the back of the tray. Be sure they are cleans as well as the plastic space between them. Then using compressed air clean where the contacts enter the machine in the rear. Usually there is moisture back there and the machine assumes the tray is full of water.
Jul 26, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
Stuck in cleaning mode?
Open the preground coffee lid, drop a cleaning tablet in it, let it do it's tablet cleaning cycle. After cycle empty water out of tray and clean.
May 16, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
I keep getting tray empty message when the tray is in fact emty
Try to snap out the metal contacts on the tray and clean behind them. Make sure that everything has dried up before you reassemble.
Jul 19, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Impressa E8: even though I did clean machine, it asks me again...
Make sure your water tank to fill, when you start the clean process, and the tray is empty and wiped down. Then add a 500ml container under the spout rather than let the water go into the tray.
Also if you have not serviced the machine for about 5,000 cups this can occur.
Mar 23, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
10,281 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
