I TURN ON MY PRINTER AND AFTER ALL THE START UP PROCESS ALL THE LIGHTS STAY ON. ON THE LCD DISPLAY "SYSTEM ERROR A04". I UNPLUG THE POWER CABLE. I DISCONNECT THE USB CABLE. I TOOK THE CARTRIDGES OUT. NOTHING SEEMS TO WORK. WHAT CAN I DO? THANK YOU IN ADVANCE.
Please visit the Lexmark website to download and install the
Lexmark X83 Printer Driver on your computer. Select your operating system
> click on "FILTER" > click on the driver under Recommended
Downloads > download and execute the file. Simply follow the instructions on
your computer screen to complete the installation.
Should you really need the installation disc, please contact Lexmark Technical Support Center for assistance.
Hello Sir or Madame,
I received System Error A04 when I attempted to install new cartridges. *I had previously changed my cartridges, but nothing would print ---- only the alignment page & the test page prints, but not any regular document I try to print.
Please let me know what I need to do!
Sincerely,
Katie Morgan ([email protected])
recenlty changed cartridges plus reinstalled software. all lights are lit up . power button will not turn on and off. seems to be stuck
all lights are lit up . power button will not turn on and off. disconnected and reconnected power chord. Nothing happenend
When my X83 would show signs of when turned on the printer would spool for 10 seconds or so then I would get an error A04, then the display would turn off , The problem I found was not a paper jam nor a item jamed in the rollers what I found and this was after the X83 was completely disassembled and I found that the little paper switch , the little plastic arm about 1 inch or so it's what tells the printer that there is paper or not that is being fed into the printer , it's location is with the paper hopper removed ( PLEASE BECAREFUL NOT TO LOOSE THE LITTLE GEARS ON THE RIGHT OF THE HOPPER) THE GEARS CAN FALL OFF VERY EASY AND GET LOST), the switch it on the left of the rollers , I had a problem with the paper switch, it was jamed and was not able to tell the printer if there was paper in the hopper or not , when I un stuck the little arm the printer worked fine.....
I have the same problem
