Question about Leapster Learning System
How do I get the batter cover off a Leapster?!?!?!?!?
I'm trying to replace the battery on my daughter's Leapster but although I can get the screw to turn and pop out with a coin, I can't remover the battery cover. Help!!!! She's home sick today and I'm running out of things for her to do!!!!
Thank you!!
  • 4 more comments
  • Anonymous Dec 12, 2008
    Cannot get the cover off the leapster
  • Anonymous Dec 16, 2008
    cannot get the back off of the leapster.
    same problem
  • sshelkrot Dec 25, 2008
    Not helpful. The screw does not pop out all the way.
  • Anonymous Mar 02, 2009
    I'm having the same problem. the screw is up but the compartment is not opening help
  • Lizzett Zavala
    Lizzett Zavala Oct 08, 2018
    slide it off on top or like put your hand on top of it and slide it of with pressure it comes off but i need to put new batteries on it and am 12 and its hard am nit that smart i am just trying to reuse my old stuff that i have in my house.
OK, after nearly breaking my daughter's leapster I have figured it out.
Use the coin and twist the little screw up. Then with the screw part closest to your chest, SLIDE the cover off AWAY from your chest. The batteries are located on the undercarriage of the cover. It takes "4" AA's
Hope this helps everyone!!!
Amy Rocka
Posted on Dec 16, 2008
  • Julie Sep 23, 2013
    Thank you for sharing! Your directions were very clear and simple. It worked perfectly!
If the battery compartment lid is not sliding out after you have loosened the screw, press the coin in the gap created from what short distance it did slide, and use the coin to force the battery compartment forward. Mine was really stuck, and this did the trick after some serious effort.
Posted on Dec 26, 2008
  • ogletreeterr Jun 16, 2011
    Thank you sooo much sshelkrot. I thought I would break it, but using a knife I finally forced it open, and now it works! thanks tl
    New Friend:
HI SORRY BUT WERE IS THE SCREW HAVING A REAL PROBLEM REMOVING THE BATTERY COVER???????????? HELP
Posted on Dec 17, 2012
SOURCE:
Forget the code for enter parent lock i no remember the code for leap frog
Instructions
    • 1Put the screwdriver into the screw hole in the small panel on the back of the Leapster. Remove the screw, and open the panel.
    • 2 Remove the batteries from the Leapster and discard them. Find the small "reset" button behind the panel cover. The reset button should be black or red
    • 3 Press the reset button with the pointed object. Hold the button down for about three to five seconds.
    • 4 Put fresh batteries into the battery chamber. Make sure the flat side of each battery connects with the springs in each battery channel. Screw the panel cover back into place.
    • 5 Press the Leapster's "on/off" button. When the Leapster comes on, enter the country informationicon1.png and the player's name.
    • 6 Press the "hint" button, which opens a pop-up help menu. Press the "A" button. Use the stylus to touch the center of the small crosshairs on the screen to calibrate the touch screen.
Read more: http://www.ehow.com/how_8430044_reset-leapfrog-leapster.html#ixzz33FgzCf1j
May 31, 2014 | Toys
My daughter's Leapster 2 Handheld game's screen is dark. She cannot see any of her games that she tries to play. I tried using the brightening button, but it doesn't help. Also, have replaced the batteries...
are the batteries you are using the correct size/voltage for the leapster? I believe it takes 4 AA/LR6 size batteries at 1.5V each.
has the product been dropped or bashed?
May 04, 2011 | Leapster 2 Handheld Game
Battery location
Battery is located on back of unit. Need screwdriver to loosen/remove screw & cover should slide off
Jul 27, 2010 | Leapster Learning System
Just replaced batteries. Screen won't responsed to pen touch.
Look at the link below under "Calibration." My daughter's Leapster did the exact same thing, and this fixed it immediately.
Apr 05, 2010 | LeapFrog Leapster 2 Learning System
Hi my daughter's leapster screen is not
THE SENSOR IS BAD ,TAKE IT BACK TO STORE AND ASK FOR ANOTHER ONE,IF BOUGHT AT WAL-MART AND THEY GIVE U PROBLEM TELL THEM U R GOIN TO CALL 1 800 WAL MART THEN DO IT WHILE IN STORE THEY WILL MAKE THEM EXCHANGE IT
Jul 14, 2009 | LeapFrog Leapster 2 Learning System
Owners manual
how do I remove the names that were originally put in and add my sons name to the leapster 2
Jan 04, 2009 | Leapster Learning System
Won't turn on.
call customer service 800-701-5327 they might be willing to replace it even after warranty has expired.
Dec 11, 2008 | Leapster Learning System
Leapster not powering on
I have never used the Leapster before, But I researched it a bit and discovered that it uses "AA" Batteries. Were the rechargeable batteries you used before designed for the Leapster or were they older Ni-Cad (Nickel Cadmium) style batteries? Older Ni-Cads put out a slightly higher voltage than standard (1.7v) as opposed to the standard 1.5v. This could possibly cause problems. If you have only had it for a few months than it should be warranty protected. Hope this helps. Cheers!
Aug 31, 2008 | Video Game Consoles & Games
Leapster Learning System Logo
6,950 people viewed this question
Top Leapster Toys Experts
James Hensley
James Hensley
Dennis Crouse
JessicaChane2345
Are you a Leapster Toy Expert? Answer questions, earn points and help others
