It wouldn't steam because it wasnt getting hot
If your H2O mop will not steam:
1. Ensure you have followed the operating instructions.
2. Ensure you have followed the troubleshooting instructions.
If the unit fails to produce steam:
3. Switch off the power at the outlet.
4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
Note: Unless the cone is submerged in water, the unit will not steam.
SOURCE: My h2o mop will not
Try running a solution of 1 part white vinegar to 2 parts water,turn on & let run through if this dosn't work take the mop head off ( unplugged of course) & poke a needle or paper clip through the hole replace head & try vinegar solution agian. It worked for mine you need to clean out lime scale.
mine won't steam either and it's not that old....the water does get hot but no steam....
same thing for mine ' Lisa , hey what do we think ! ITS made in CHINA !!!!! ALL GARBAGE STUFF .
mine wont work either no steam but the lights work. it wont heat up
sorry I got
