Battery getting extremely hot and then drains out,replaced battery,its charging but getting extremely hot and amber light not coming on but charging,when unplug charger and use the fone its still getting hot,i believe there is software to flush the fone
SOURCE: the battery drains off very
Go to teh phone settings, and under sync accounts disable all teh sync accounts that you are not using such as stocks etc. These constantly use up data and hence drains your battery as they do so in teh background. This should greatly improve your battery. If not, your battery must eb damaged and i woudl suggest you purchase an extended battery which may have up to 40% more battery life.
SOURCE: my sony ericsson 980i wont charge. the red light
If you are lucky, this problem cause of your charger or your battery. First you can try to charge your phone with a different battery or charger. If these ways do not solve your problem, you have to reinstall W980 program which you can reach from SonyEricsson's web site. But you have to try backup your datas, otherwise unfortunatel all of your datas' will be lost.
Erhan
SOURCE: my htc wildfire is not charging, there is no red
Problem with either
- Battery - gone real dead. Get a new one.
- Charger - gone dead due to some electrical fault. Get a new one.
If both are fine.. the problem with internal circuit. Only a HTC technician could help fixing this.
SOURCE: Left my HTC Wildfire on charge overnight. Now I
Hi
To remove the back cover
With the phone turned off, hold your phone securely with the front facing down.
With your thumb or finger, lift the back cover off from the small opening (above the camera) on the top of your phone.
You may need to perform a factory reset if this doesn't work, however a factory reset is not a step to be taken lightly. It will permanently delete all your
data (including any contacts stored on the phone and customized settings, and will also remove any applications you've downloaded
and installed.
To do the factory reset
Hope all this helps
Here is the settings for GPRS on your HTC Wildfire A333 mobile:
Account Name: idea_GPRS
Username: leave Blank
Password: leave Blank
Homepage: http://wap.ideafresh.com
Proxy and Server Port: 8080
Proxy and Server adress: 010.004.042.045
Databearer: GPRS / Packetdata
Access Point Name: imis
Proxy: Enabled/yes
Authentication Type: Normal
Thanks,
Shiva
