It just seems that it is not getting power.
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
none
Just stopped working. No fan, no cooling. Kerplut.
Sorry, too late; we discarded the unit before Christmas.
Thanks for responding
I had an issue where The exterior fan would not turn and the unit appeared to do nothing. I cut the Wires to the TEC (Peltier) and BAM fans started running again, the Power Supply is likely "Internally Protected" so that when there is too much draw it essentially shuts down. My unit was making a very high pitched noise when plugged in before I Disconnected the TEC. no the noise is gone. The Board was a C3909-C from Hanny.com.cn
Haier Model Number HVW12ABB
