SOURCE: reset
when i open my latop toshiba A215-S5822 that time it shows enter password..bios passwork block in laptop plz send me a solution to solve this problem....thank u
SOURCE: Toshiba Satellite A215-S5818 boot then it goes off
is there anywhere were i can obtain a free data recovery program?
SOURCE: how do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
SOURCE: My Toshiba A215-S5818 Shows up enter password
The problem can be due to incorrect power on password prompt. This problem is noticed with some older BIOS versions. The system is looking for a non-existing power-on password.
The only solution for this is to send the system back to Toshiba. They will repair this problem free of cost.
SOURCE: I am looking to restore
Hello
The factory reseting procedure is defined on the link mentioned below
http://aps2.toshiba-tro.de/kb0/HTD9102IR0000R01.htm
Good Luck, and do rate the solution if got help
