SOURCE: mailbox full how do we clear it (Panasonic KX-T7633
It sounds like your mailbox is full. Maybe your mailbox is set to not allow enough messages or enough time. If you simply have too many messages that are hang-ups or the like and you would simply like to start over, the easiest thing to do is delete the mailbox and create a new one.
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
SOURCE: CHANGING THE TIME ON PHONE
I can give you the fast answer and the slow answer. Fast one is to go to the main phone, press PROG and dial **1234. The system should go into programming and you will be looking at system program 000. ENTER. From there, using a combination of the SEL, FWD and CONF keys, you should be able to navigate around the time change, using ENTER or STORE to save it.
The arder way is to grab the manual here http://www.public.carl.airpost.net/TDA/TDA_PTPM_32.pdf and start reading it from page 12 then follow the instructions on page 16.
Keep in mind that TDA programming is usually done from the master phone, or any phone assigned programming status. It may be all or NONE.
Carl
SOURCE: How do I change my message on the phone. KX-T7665
dial 100 and select 5 for mailbox management
SOURCE: How do you change the display to show the date and
Since you can't exactly press the INFO softkey :-)
Try the TRANSFER button on an idle phone. It has 3 steps, one of them will be the date and time.
Carl
SOURCE: I have a panasonic KX-T7665 how do I forward calls
The simple answer is on the intercom dial *7102 9 number #. That forwards all calls outside. However, outside line and trunk-to-trunk programming has to be programmed into the system.
There are other conditions located in the Operating Manual under Call Forward. In mine, it's on page 71.
Carl
