Question about Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1
Battery hookup for a 35 hp vanguard
I see a couple of harnesses that are already conected to other harnesses, but I see no loose wires that I can trace back to either the starter switch or starter motor. Any direction or links for specific wiring diagrams would be greatly appreciated.
    Sergeant:
  • 406 Answers
Follow the wires from the solenoid its wires go from the battery to the starter, a small wire on it comes from the switch it would be the wire from the switch that is the furtherest on the switch "starting " blade on the switch..the heavy wire to the starter should be red the small wires black..good luck
Posted on Nov 08, 2014
4 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: i am looking for a wiring diagram on a vanguard
i will try to help. here is a website http://www.cartpartsplus.com/club-car-engine-upgrade-kit-18-hp.html and the forum http://forums.cartpartsplus.com/index.php. the forum will be your best bet.
Posted on Jan 06, 2010
SOURCE: New Vanguard starter only spins slowly even when
Did you ever get an answer? Mine is doing the same. I think the starter is toast. I bought a new battery, but spins just as slow. Thanks Ken
Posted on May 05, 2010
  • 4088 Answers
SOURCE: Briggs and Stratton Vanguard 23Hp starter issues
The starter may need shims between the engine and starter to permit the relative gears to release. Compare the two starters, if you still have the old one, for shaft length and bendix construction. Hope this helps!
Posted on Jun 06, 2010
Testimonial: "drallim, Everything checks out, cannot believe I've received 2 bad solenoids from NAPA. I had bought a new one and exchanged it because it seemed the switch was sticking. Still have not solved problem. Thank you for your time and efforts. Tim"
My Vanguard 23hp engine stopped charging the battery. Do I have to replace the starter?
no
starters do not charge batteries . they just start engines
have the voltage regulator checked and the charging circuit checked for broken wires , loose terminals
Aug 03, 2018 | Tools & Hardware - Others
My 23hp Vanguard motor stalls every so often, To restart it I have to turn the battery isolator switch off then back on again before it will restart. could it be to do with the oil pressure switch
stalling
yes oil pressure switch's /modules are wired in to the spark systems of small plant motors as motor protection
i cant see one listed as a part for sale for 23 hp vanguard briggs
or mentioned in the user manual
386447 3079
if oil level is ok and oil pressure switch isnt the problem
check the governor adjustment
or adjust the idle
very simplistic drawing
386447 3079
Oct 20, 2016 | HP Tools & Hardware - Others
What is the most popular item goes bad when throw code po882 on a 2006 pt cruiser non turbo 2.4??
This is a code for the 12v relay supply to the transmission. Check the fuses in the underhood relay/fuse box to make sure none are blown causing this code. If all are ok, it will take electrical diagnostics to isolate the source of the problem by checking wiring/control module etc.
Jun 07, 2015 | 2006 Chrysler PT Cruiser
Starter not turn over 35 hp
check that the engine is not seized. have a load test done on the battery as it may be flat or have a dead cell
Dec 02, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Blower motor not working. fuses appear to be ok. was working fine yesterday. any ideas?
Test the blower motor, turn on the switch and then with a test light conect it something that is grounded. Check for power at the harness, then connect the test light to the power side of the battery and test for grown at the harness if you have power and and ground replace the blower.
Feb 11, 2011 | 1995 Ford Mustang
I am teying to wire a motor it is 18 hp 2 cil i
NO, no fuses anywhere actually, except maybe in the main positive wire from battery?
Feb 22, 2010 | Desa International 18hp Briggs And...
Briggs 12.5hp vanguard stopped n smoke at rear.
Its possible that the spark caused an in-line fuse to blow. Try following the wires from the battery to the ignition switch to the starter. There is probably at least one fuse in that path.
Jul 25, 2009 | Garden
No running lights on my trailer.
Turn your headlights on and use a test light to check the harness on your vehicle to make sure you are getting power through the connection. If so, connect the trailer plug into your the trailer receptacle on your vehicle and cut probe through the correct wire after the harness. This will check to ensure you are getting fire through the conection. Always start at your vehicle and work to the trailer. If you are not getting power through the conection, check for a loose wire or replace connector... this is where you will find your problem more than likely. If you're getting power through your harness, you are loosing power between your plug and your lights. Probably a short in the wire. It will be easier to replace the wire instead of trying to locate the short. Good luck!!
Jun 11, 2009 | 1995 Chevrolet K1500
Model 2780R intermittant Picture & Sound Failure
The set has loose power conections to the tuner and judging by the model it might have other loose conections in the chassis,the loose conections need to be resoldered and might not be easy to find,try taping the side of the set to see if it reacts while is doing the problem.Be safe and call a technician unless you are familiar with tv service.
Sep 20, 2006 | Sony KV-27FV16 TV
Briggs & Stratton Briggs Stratton Vanguard V - Twin Vertical Ohv Engine with Electric Start 23 Hp, 1" X 3 5/32" Shaft, ModelNo. 386777 - 0036 - E1 Logo
519 people viewed this question
Top Briggs & Stratton Tools & Hardware - Others Experts
Bill Boyd
Randy Schumann
Randy Schumann
Tom Chichester
Are you a Briggs & Stratton Tool and Hardware - Other Expert? Answer questions, earn points and help others
