Refrigerators Logo
Anonymous Posted on Apr 21, 2012
Supco wiring an old freezer. Orange wire?
I am wiring in a Supco 3 in 1 hard start in an old freezer that lacks replacement relay parts. My compressor has 3 pins. From the freezer I have a power line that went into a guardette (that I removed). I wired that into one of the Supco power lines (black). I also have an orange line and that is what I am curious about. The schematics show the Orange line feeds into the case heater. The orange line used to connect directly into the compressor. Now it is not, I connected it to the other black (power) line of the Supco. Is this correct? The freezer appears to run. . .
  • Anonymous Apr 21, 2012
    Okay that is helpful and I can check the schematic but not having much electrical knowledge how would I tell if it has a neutral?
  • mike cooper Apr 21, 2012
    The schematic will show the heater and two ends. One will join up with all the neutrals which may be at the compressor or at a neutral connector. The other end will be the live. If the heater isn't working, join the orange to the live on the Supco and recheck
mike cooper
Level 3:
  • Refrigerators Master 884 Answers
  • Posted on Apr 21, 2012
mike cooper
Level 3:
Answers
884
Questions
Helped
404879
Points
1991
Was the orange wire on a switched live on the old compressor connections? It may come on when the compressor goes off in that case. If not, recheck the schematic for the other end of the heater. If it has a neutral, join the orange to the live feed to the supco. If it has a live, leave the orange on the neutral of the supco.
Testimonial: "Thank you!"
2helpful
2answers
2 wires coming out of Run Capacitor orange and white; Orange goes to fan and ice maker and inside defrost timer,White to same Run Capacitor ; same Orange & White to Start Relay, how hook up 3in1 ?
this will creat feedback run all through 2 duel pole relays protecting run return supply easiy enough just protect system supply individual supply and short
Emerson model#CR519B. The unit just stopped working. If plugged in a motor runs for about 8 seconds and clicks off; about a minute later it repeats. Help
I had the same problem with a small wine cooler. It happened to me twice in 6 years. Both times I had to replace the starter relay.
I couldn't find any repair facilities willing to work on these small wine coolers or refrigerators, probably because the bill would be more than the used fridge is worth. If you feel confident around a volt/ohm meter and electricity, you could learn how to test this and maybe fix it yourself.
You shouldn't do any of this if you aren't familiar with using a Volt/Ohm meter and can safely and confidently work around electricity.:
  1. Unplug the fridge
  2. I first tested the compressor with an Ohm Meter (see how with youtube video below or by reading how at Davesrepair.com). It was good, but it kept starting and stopping within a few seconds.
  3. Basically my starter capacitor/relay wasn't working. It supplies temporary starting voltage to the starter relay in the compressor, then cuts off to allow the motor to run.
  4. I bought a Supco 3-in-1 on Amazon for less than $13 and hooked it up according to the supplied instructions. It lasted about 3 years.
Of course, the factory recommended repair is to buy the original replacement relay, but it will be more costly and harder to find.
I bought a Supco 3 in 1 Hard Start relay sized for the HP on my compressor. Mine was the Supco RCO810 (see link below).
NOTE: Before I replaced the starter relay and overload protection with a Supco 3 in 1, I learned how to test the compressor with a Volt/Ohm meter. If you don't have a meter, you can buy them online or inexpensive to free with a coupon at Harbor Freight.
2helpful
What rewiring is needed to replace the overload relay with a universal kit, on an upright freezer? Kelvinator model VA16 W. There are two relays that connect to the compressor that need to be replaced....
The two pieces are Relay and Overload.
If you are using a supco relay/overload combination that has three wires with terminals and two wires with stripped ends the wiring is as such.
Red-Run Terminal, White-Start Terminal, Black-Common Terminal (Overload was wired to this)
Stripped wires are connected to line cord along with condenser fan wires.
Freezer not freezing, refrigertor seems to be working fine. making an intermittent clicking sound
your compressor is not running ..the clicking sound is the compressor start relay ..hard start capacitor ..../relay/overload all in one..will fix this problem call your local appliance parts/or used appliance store for this part ..the wiring is simple //remove compressor cover to view relay ...remove it with screwdriver ..dont worry about breaking this relay .remove it to see 3 terminals ..one is start /one is run /one is common ./look at diagram on the hard start and wire it to the correct compressor pin/terminal then wire the 2 wires off old relay to the power wires to new hard start ...it will work again ...believe me ..the part cost around 20.00 let me know ..good luck../joe/
1helpful
I have 20 yeras old Maytag model GT1928PVCW which we were very happy. Unfortauantly it just stop cooling. Fans steel working but no cooling. Is it possible to repair
Yes it is, for sure. We just need to diagnose the problem. First, if you unit has ice on the back inside wall of the freezer, you have a defrost problem that can mostlilely be solved by replacing the defrost heater. If not, we will move on.
If you can read a wiring diagram, go to www.partselect.com and enter your model number. This will bring up a blown up diagram so you can locate evey part or you unit plus your in luck, it also has wa wiring diagram included. By looking a the wiring diagram, there are only four thing that will prevent your compressor from running.
  1. Temp control
  2. Defrost timer
  3. Run cap.,Over load, PTC Relay
Checking temp control/ Take the two wires from part and connect together. If the unit starts running, you will need to replace control.
Defrost timer/ It has a round piece in the front of it with a slot on each side of the round piece that will let you turn it in only one direction. You can take a flat blade screw driver and turn. This advances the timer. Turn until you hear it click. If unit starts running, replace timer.
Run capacitor, overload and PTC relay/ If you can hear the compressor clicking around every 5 to 10 seconds, you will need to replace the part. The bast thing to do is replace all three pieces with a Supco 3 in 1. You can search Supco 3 in 1 and find one on the web. If you can use a meter, you might want to check your compressor to see if the windings are grounded. Take anyone of the 3 post coming out of the compressor and check continuity between it and ground. If it has continuity, it's bad and will cost a lot to replace. Also check for continuity between each post. If there is continuity, this is great and the Supco 3 in 1 will fix the problem. I have made this as simple as I know how but I also know that it's not simple to peolpe that don't work on these everyday like myself. I hope you the best and good luck. If you have anymore questions, please respond back and I'll do my best.
3helpful
2answers
Compressor problem, installing the Supco 3-in-1 Relay
Hi, If the 3 posts are top center and bottom right left, the black wire goes top the top center post. The red wire will go to the bottom right and the white goes to bottom left.
If the posts are bottom center and top right left, the black goes on bottom center and the red goes top left. The white goes top right.
If you do not see a capacitor, disregaurd the wires in the 3-1
I hope this helps you. Please let me know if I can assist you further.
Vic
5helpful
2answers
Need to Install a Supco 3 n 1 start capacitor
3 in 1 starters like the supco that you have pictured can and will cause premature failure of your compressor. newer compressors are not designed to handle the start up current the 3-n-1 provides. I reccomend replaing wiht an original oem part the part number is 8201786. If you still want to use the hard start use the 410 model obviously hook up the red white and blak wires to the compressor the 2 left over leads will connect to the 2 original wires that come in to the compressor I beleive they are red and white. polarity does not matter. good luck Peyton
2answers
Maytag MZD2766GEW No Cooling
hi thanks for the question . i would replace the relay and the cap then your sure your good to go. thanks te appliance doc rate me please
Relay clicks, compressor doesn't start
try replacing the relay/ overload you can buy a supco replacement there's 2 of them one covers 1/15 - 1/6 and the other covers1/3 - 1/4 its really easy to wire up and cost effective. any questions don't hesitate to contact by e-mail [email protected]
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
