SOURCE: The battery doesn't stay charged in Guardian 10K
I think that is the problem as well. Temporarily, you could just buy a tricke charger from the parts house and hook that up until your other one is changed. Rick
SOURCE: guardian rv generator
Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
SOURCE: The generator will not run
I had an 8kw unit from Guardian I put in last year. The starter was defective direct from the factory. If your battery is at full charge and voltage good, with tight connections to the starter it may boil down to the starter itself. Call the warrenty dept. for the company and tell them it should be covered.
SOURCE: I have a guardian quietpact
This is likely a problem with the voltage regulator or the wiring. If this unit has brushes/sliprings for field excitation check the condition of those.
SOURCE: My Guardian generator Quietpact 40G makes a
if the noise is coming from the solenoid attached to the top of the starter replace it for the windings are shorted out causing the noise you hear
