Check the AC line if it is gets cold when AC is on, if it doesnt that may mean there is a problem with the compressor or out of gas due to leakage. Also check if there is an electrical connection problem.
Good luck, summer with no AC really becomes annoying.
sounds like your feeling air flow from motion your blower dosen't sound like its coming on try when you are sitting still with car running turnibg on the blower if it dosen't come on it could be anything from a bad fuse to a bad blower motor
check the blower fan on inside of dryer. it sounds like something is wrong with it. this fan is where the dryer gets the air to blow it out threw vent pipe to outside. good-day !
you might have a problem with your heater core ,also check your radiator and make sure it is full if you are low on water that will also cause cold air to blow or your actuator witch is a control switch that opens the vale to let hot water pass through giving you hot air good luck
Roger it sounds like the blower motor is not comming on. There is a resistor network located in the engine compartment on the passenger side mounted to the firewall, that controlls the blower motor. The connections may have corroted or the unit itself is bad. That was the first thing I had to relpace when I got my used 92 Dakota. There is also a 30 amp fuse in the fuse box under the dash board . If that is blown I would suspect the blower motor is seized up or just pulling too much power.
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
