My pocket quad do not have any wiring install the only wiring is the stop engine button
I think you want to put a light on it??? you will need to install a battery to do it right. BUT you can run a LED light right off the magnito. connect to the wire to the wire on the mag that goes to the kill button, Start the engine and check the voltage, if it is more than 14 Volts you need to install a rectifier to drop the voltage down. You can do it with a good resistor if its not too high. Remember... the engine is designed to make enough power to run the engine only. A LED light uses 1/5 the power of a incandescent light so that might work for you.
SOURCE: i have a 49cc atv
Hi patandsheri...
Your problem could be numerous and none of them good.
1...Broken crankshaft
2...Broken connecting rod
3...Blown Head Gasket
4...Broken or stuck intake or exaust valve, also could have lost the lock pieces to hold them in place.
5. Broken timing chain or gear
6. Hole in head or hole in engine
Please take time to rate me
