Intermatic does not post that product manual, or the door label for that specific product. Nor is the door label clear when viewing images of timer.
Copy following links for possible assistance wiring timer, and then setting timer:
http://waterheatertimer.org/pdf/RC2403RT-Door Label.pdf
http://waterheatertimer.org/How-to-set-timers.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: need instructions on how to set timer
Here's a link to Intermatic manuals on-line:
http://www.intermatic.com/Default.asp?action=cat&cid=91
SOURCE: Instruction manual to program HB77R
Here is the instruction manual your looking for:
Intermatic HB77R
Hope this helps and please remember to rate this!
SOURCE: How To Program An Intermatic PE15300 Pool Timer ?
1. Press PROG Key to cycle through menu options.
2. Press UP and DOWN arrow keys to change program settings.
3. Press ENTER key to save changes and exit programming mode.
4. Press ON/OFF keys to manually turn devices ON or OFF.
Please post back if additional info is needed
Please take time to rate this fixya
SOURCE: INstruction manual needed Intermatic HB800RCL
To download the file you need Acrobat reader 7 at least. I just tried it and I was able to get it. It was slow but got it. Go for it and hop this was helpful!
