SOURCE: dishes on top rack not getting clean. Actually
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
SOURCE: Top Rack doesn't get clean
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
SOURCE: The top rack. (Glasses) has
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Hi If the top rack of the dishwasher
doesn't get clean, check your appliance to see if you can fix the problem. Then check to see if your
dishwasher has clogged filters. Filters generally cover the drain valve area to
catch debris as the water drains from the dishwasher. Many dishwashers have
maintenance-free filters, but your dishwasher may have filters that need
cleaning. Read your owner's manual before you perform any filter maintenance to
avoid damaging your dishwasher. Check your water temperature to
make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not
be hot enough to clean dishes effectively. Turn your kitchen hot water tap on
and wait until the water warms up completely. Fill a cup and measure the water
temperature with a kitchen thermometer. If the water is less than 120 degrees
Fahrenheit, turn your water heater up to 120 degrees. Load the top rack properly. Place
cups and bowls upside down in the rack and don't nest dishes because this can
prevent water from reaching dishes. Don't overload the top rack. Instead,
position each item so the dirty areas of the dishes will receive full contact
with water spraying up from the main spray arm located beneath the top rack.
Prevent items from hanging below the top rack, which could prevent the spray
arm from rotating. Also check this link for more helpful
info:- http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html Please get back to us if you have
further query else please accept the suggestion.
First
check the spray Arms to make sure the holes in the spray arms are free and
clear of debris. Your dishwasher should have several spray arms, including one
at the bottom of the tub, one under the top rack, and possibly a third spray
arm on the top of the tub. Sometimes food and mineral deposits can block holes
in the spray arms, preventing water from spraying effectively. If this occurs,
warm some white vinegar and pour it into a spray bottle. Spray the holes with
the vinegar and dislodge debris with a toothpick or large safety pin.
Thank you for contacting fixya.com
