What key on the keyboard is key 69?
Hello Scott, Make sure that there are no objects placed on the keyboard, or if you have one, the external keyboard. Turn off the computer, and turn off all attached devices. Turn on the computer first; If an external keyboard is connected, do the following: v Turn off the computer and disconnect the external keyboard; then turn on the computer. Make sure that the built-in keyboard operates correctly. If it does, have the external keyboard serviced. Make sure that the external keyboard is connected to the
then turn on the attached devices.
correct connector.
Please feel free to ask me if you any further questions or concerns.
Also please rate me if you like my answer, that helps me alot.
Thanks.
Sounds like one of two things...
1. Somebody spilled somthing or got some sticky junk in there and one of the keys is semi gummy.
2. The machine got banged around once too many times and one of the connections is slightly ajar.
So basically it sounds like it's hardware and not software, so you'll probably have to pull it apart yourself, or else take it to someone
