I bought this used, and replaced the battery, but the train wont go forward. it only goes backwards. this train does not have a forward or reverse button. it only has a "go" button. thanks
SOURCE: peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
SOURCE: very slow 2nd hand peg perego gaucho
I have the same issue. Called their customer service and they said it was a defect in the charging system. They are sending a upgrade kit for free, but when it's installed you can't charge the battery using the rear port anymore. No big deal. I'll report back when the fix is complete. 5-7 days until it gets here.
SOURCE: I just put together a Peg perego Polaris RZR ride
For this Peg Perego Razor model, some of them have a lever that slips over the foot pedal to keep it from going in reverse for safety reasons.
I would check the foot pedal and see if it has one.
Let me know what you find.
SOURCE: John Deere Gator not responding with new battery.
I upgraded my Peg Perego shifter and it came with the wiring harness.
I bought it at http://www.shopjandl.com/
Hope this helps.
