I tried different tensions but it still jams after sewing correctly for a short time
Start from the begining.
Use your Instruction Book and make sure the machine is threaded correctly.
Put in a new needle.
Adjust the top tension to about halfway.
Fit a fresh wound bobbin that does not have all sorts of different threads still wound on it(a bad habit with a lot of people).
Make sure the bottom tension is correct.
Make sure the bobbin is fitted corectly.
Set the machine to do basic straight stitch(mid range stitch length).
Try sewing and see if the problem is solved.
Try changing the needle
clean under the needle plate & in the bobbin area for lint or loose threads
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
SOURCE: Singer 6217C Bobbin Thread bunching
please check out this link
http://sewvacdoctor.com/cate.asp?categoryID=6#1082
goodluck
thanks.
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
