I got a new d-link ADSL-2730u router. when i am trying to install it following the cd instructions it always ends by the same error message: "click'n connect can't discover the router.please check the cable connection and Make sure the router is power on
SOURCE: I have a d link
Welcome to Fixya
Try to turn off/on the dlink router first. Reisntall the driver of your ethernet adapter. check your computer's IP address by going to command prompt and type in ipconfig. This is to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router. If you have 169.x.x IP address, Reboot your computer, router (if present) and broadband modem together, then re-test your connection. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
i got the problem solved
it was the wireless adapter, it turned it off and started the procedure all over again and it worked.....i hope this will help someone...thank you
wireless adapter means the power cord right?
wireless adapter means that power cord?
