SOURCE: Printing problem "PCL XL error"
here are the steps to remedy the problem:
1.right click the printer and go to the properties.
2.click on the advanced tab and uncheck 'enabled printing features'
3.click on the general tab and click on 'printing preferences'
4.click on the 'advanced' tab and disable the 'print optimizations'
hopefully it works for you guys.
cheers.
Dear Sir
My printer is laserjet 1320
PCL XL error
Subsystem: KERNEL
Error: Illegal Tag
Operator: 0x1b
Position: 6
Pls. This problem solution give me.
SOURCE: pcl xl error warning: Illegal media source
Some people have issues with the PCL6 driver this causes pcl xl error like this to print. Change your driver from the PCL6 driver to the PCL5 driver. If you don't have the software you can down load it from HP at: http://welcome.hp.com/country/us/en/support.html
Thanks...V
PCL XL ERROR subsystem: Kernel Error: Illegal Tag Operator :0 x 1b Position: 6
We have a WorkCentre 7655 that has been working fine for ages but is now causing some issues. A user who is running Windows 7 32 bit edition is sending files to print (using the secure print function) - the system is reporting they have spooled fine to the printer - but when they go and release the document they are getting (more often than not) about 16 out of 21 pages (for example) and then a PCL XL Error (Subsystem: Text, InternalError 0x50, Operator: Text, Position: 8564). I have another document that 9 times out of ten will actually crash the WorkCentre completely and cause it to reboot mid way through printing.
The driver we are using is the latest: "Xerox WorkCentre 7655 rev 2.0 PCL6"
As mentioned the user is running Windows 7 - the printer is shared from a Windows 2003 Server which has the same version of the driver.
