Did print shop 3 work properly in win 7? If so you should never have updated. See all the grief it has caused you? Go back and install the 3.0 version and leave well enough alone
Or maybe that program is not compatible at all with your OS.I have mo bo's that will not load XP but will work fine with anything prior to that. Computers are unpredictable and down right ornery at times but we need them so have to play by their rules.
SOURCE: can't run Print Shop Deluxe version 23
You will need Microsoft .NET Framework to run some instances of Print Shop Deluxe. If you install it, the patch will not work without .NET Framework installed.
SOURCE: Quicken launcher has stopped working, how do I
This will occur if you have any very long security symbols -- it happened to me when I entered some of the new option symbols which can run 20 characters or more. I did not check to see exactly how long they can be but editing the security list and reducing them to 15 characters or less solved the problem.
SOURCE: Windows 7 and Mathcad 14 compatibility
can anyone get me information whether Mathcad 14 is working on Windows 7
Thanks in advance
SOURCE: Running Windows 7 and Adobe
It has to do with the file name including the path being longer than 63 characters. Copy the file to a shorter path, i.e. c:\a\ and try that.
SOURCE: can not update program as error code AUSE099 comes
Go to Control Panel, Add remove programmes. find Microsoft .net framework 3.5 sp1 click remove if this fails then remove 3.0
