Toshiba Satellite A135-S4527 Notebook Logo
Posted on Nov 15, 2008
My dvd drive in my computer won't play dvds
My computer's dvd drive doesn't work, it can play cds and it can burn disks but it can't play dvds. I have tried to put in multiple dvds that all work on other computers and dvd players, but my computer only reads them as blank disk.
please help me with this
I have a Toshiba Laptop with a Pioneer DVD-RW Device. The CD works fine but the DVD tries to start and but eventually quits. I am using Vista and the instructions for the same problem with XP don't seem to work. Thanks...
  • bdf1816 Nov 18, 2008
    I tried this solution and got the same result. The DVD tries to start several times but then just quits.
    Thanks. I will try cleaning.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Nov 15, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
1416
Points
14
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
  • Anonymous Nov 18, 2008
    Then you might have a problem with the optical reader. Try to clean the optical lens using commercial lens cleaners. Otherwise, if cleaning does not work then you have a faulty optical unit.
My CD/DVD drive won't read/play DVDs and it won't write DVDs either. It used to do this fine, but it doesn't anymore. It will still play and write CDs, but not DVDs. I have tried EVERYTHING to...
You probably will need to replace the optical drive (CD/DVD drive) in your laptop. Go to Google and search for "Dell Inspirion 6000 CD/DVD drive" to find a replacement.
To be sure it's the CD/DVD drive that's defective and not your operating system software, you could also try to boot from a boot-able DVD disk.
The drive does not play cds nor dvds. However, it burns both cds and dvds very well. What is wrong here? How do I fix it?
The image receiver is probably bad inside the laser lens. When the laser light emits and reflects back from the disk, the receiver should pick-up the light - in this case it doesn't. It lights up because you can burn. Try another drive - external (USB) or internal (replace the one inside the computer).
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
What type of disks does my TS L632D burn? +- ,CD, DVD Can't get CD's to burn?
go to my computer and look at the cd drive.if it says cd-rom you can't burn cds,dvd-rom will not burn dvds.only cd-rw,dvd-ram,dvd/cd-rw can burn cds.dvd-+,dvd-minus and dvd ram can burn dvds
2answers
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
2answers
Dvd burner not detected
Sorry, but that model is not a DVD writer. It can only write and rewrite CD's. It can only read DVD's.
Here is a page with specs:
Sony CRX310S Specs
Note under DVD>Write DVD it says N/A. (Not applicable.)
1helpful
2answers
Why my [sony cd rw dvd rom] will not detect a blank dvd disk
If you have the sony CD RW DVD ROM then you can't burn the data in a blank DVD.
Because your Configuration is :
Read : CD / DVD
Write : CD
This means you have a combo drive. But to burn a DVD you should have DVD RW.
Dvd rom
not necessrilly some dvd rom drives play only dvds an cds but don't burn them. it may burn cds but there is a 90% chance your drive can't burn dvd's
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
