Our AEG B3101 oven is about a year old. Recently when using the oven or the grill, it seems to cut out after about 15-20 minutes of use and the boith heater and fan stop. The LED display keeps going fine. If you turn it off and leave it for ten minutes you can then turn the oven or grill back on and it works fine for another 20 minutes. I can't see any thermal cut out in the instructions in case or problems so something must be going wrong - any ideas what and where I cna locate it/test it? Thanks.
cuts out intermitantly in all settings
Hi I have a similar problem but mine only cuts out when the grill is used. I suppose there must be an overheat cut out.
I installed the oven and all the installation clearances were adhered to. I have been thinking of fitting a small computer ventillation fan in the cabinet.
Mick
We have an AEG B4104-4 oven which is 7 years old and has worked perfectly until now. Just recently it has started to trip the electricity when the left hand knob is used (ie choice of programme knob). Can you suggest what may be causing this problem ?
electric working but not fan or grill on aeg oven
Display will not change
