Posted on Apr 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't understand what development unit is
What does the developing unit look like
Anonymous
Level 2:
  • Expert 372 Answers
  • Posted on Apr 19, 2012
Anonymous
Expert
Level 2:
Answers
372
Questions
Helped
112385
Points
782
Which copier .it is mostly below the drum unit and in some copiers such as panasonic ,ricoh,konica minolta they come as a combo unit.
5 Related Answers
mustyoke
OKETAOLEGUN OLANIYI M
  • 4 Answers
  • Posted on Jan 06, 2009
SOURCE: problem with developing unit for canon ir1018
canon ir1018 showing error 354 code what is the cause
A
Anonymous
  • Posted on Apr 24, 2009
SOURCE: changing developer unit in afficio 450
Remove PCU, remove development unit, remove cover (2 plastic C-clips) remove filter, remove development roller (2 shoulder bolts). Clean roller and empty all developer. Pour in new developer, re-assemble unit. Reinstall drum and Development unit. Place a small piece of paper between the PCU and toner entrance hole to prevent used toner from entering dev. unit during calibration. Perform SP2-801. Remove paper form dev. unit
Anonymous
  • 37 Answers
  • Posted on Jun 07, 2009
SOURCE: We need to replace the drum unit on a Minolta
Not familiar with your model.... but...
When you install the toner cartridge, the toner is routed into a developer unit. this unit has "developer" in it that mixes with the toner. Generally you purchase the developer, remove the developer unit, remove the top cover of the unit, empty the contents of the unit. add the new deveoper to the unit, replace the cover, install the toner cartridge. a lot of times this requires going into service mode to reset the developer count and run a conditioning mode. Not sure if this is any help but here you go.
Cogz
Chris Coughlin
  • 1326 Answers
  • Posted on Jan 23, 2010
SOURCE: connector in developer unit is disengaged. is the
Don't know? It depends what kind of copier you have?
Anonymous
  • 287 Answers
  • Posted on Mar 20, 2010
SOURCE: copier aficio 450 developer unit plastic strip
Hello, hope this helps. I believe you are referring to the seals [a clear mylar] placed at each end of the developer roller to prevent developer from spilling out of the ends.The part numbers are A2323132 (rear seal) and A2323131( front seal). I just checked the Ricoh website and it appears they don't sell to the public. I can recommend my company which is Advanced Office Systems in Knoxville Tennessee. I have know idea what those dang things cost but after shipping and a whole lotta handling, $20 would would not shock me. I have used electrical tape to solve this problem. To make a seal, cut a piece of tape that overlaps the dev roller by about an inch at both ends. Cut a second piece of tape that when turned "sticky side to sticky side" against the first piece can provide a smooth "seal" against the dev roller while the remaining sticky ends of the first piece attach to the CLEANED plastic housing of the developer unit. or call 1.865.966.0770 to purchase the seals from Advanced Office Systems. Have a good one...
1helpful
2answers
How to fix the sharp MX-3100N printer? the message on the screen is install the developer.
Developer unit is not detected , or developer is depleted ( which is very bad , because it could mean that it spilled inside your copier , it is very abrasive)
try removing and re-installing the developer unit , and maybe try using another unit for control,
could also be your harness, see if plug of developer unit is plugged into mainbord
FS1128 whats the setup for dev on this?... is it like the CS2550 ? U130
1-5-5 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the front cover.
2. Remove the developing unit.
3. Check or replace the developing unit and
refit all the removed parts.
NOTE:
When the periodic maintenance (replacing
the maintenance kit, see page 2-4-4), perform following maintenance modes.
1. U251 Clearing the maintenance count (see
page 1-3-39)
2. U111 Clearing the drum drive time (see
page 1-3-33)
3. U130 Initial setting for the developing unit
(see page 1-3-34)
2answers
Developer unit not installed
yocera ecosys fs-1124mfp toner container 0r the developer unit is not install
Xerox Phaser 7750 The printer's black fades print after print and totally vanishes. I tried replacing Imaging Unit, Toner, cleaning by wand, etc.
If it is only happening in black then it has to be something prior to the toner reaching the transfer belt; such as toner, developer, imaging unit, or laser. It sounds like you've already cleaned the laser window, replaced the toner, and image unit, so I would inspect the developer. Remove the black image unit and use a flashlight to inspect how well toner is covering the magnetic roller on the developer. You may want to compare it to a developer of a working color to see if they look similar. Also, make sure there are no foreign objects near where the image units go. If an object came loose in there, the arm will not close correctly which could cause the image unit to not make contact with the developer. Hope this helps, and thanks for using Fixya.
Hello, I am having problems with a Di2510 machine. When it is turned on I get the 'Please Wait' screen, and then nothing? It just stays frozen on that message
sir, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Please help!!!! I am having problems with a Di2510 machine. When it is turned on I get the 'Please Wait' screen It just stays frozen on that message
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST. IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Also try removing the toner bottle, turn off the machine with the toner bottle out and cover closed turn on the machine when it ask for toner properly place the toner bottle in the machine
1helpful
I' ve a problem with copier ar 5516. i need information about using of developer. where i must to put the developer? the toner AR-021FT IS COMPATIBLE WITH THIS COPIER?
yes ar021FT toner compatible for your 5516. when replacing the developer:1) pull out the toner cartridge,2) pull out developing unit with 1 screw (blue),3) in developing unit remove 2 screws (blue) to open its top cover,4) drain d unit and replesnish with new developer. do procedure 4 to 1 to return. Good luck.
2answers
Where do you put the developer
The developer is mixed with the toner in the toner cartridge.
k24674
ADMIN Andrew
ADMIN Andrew
