3Com (3c17462) Logo
Franziska Gruber Posted on Nov 21, 2006
Stacking Cable / SuperStack3 3870
Hi. We have two 3Com SuperStack3 3870 Switches and we wanted to stack them together with the 3Com Stacking Cable [3C17462]. We put in the stacking cable and turned the power on. The led´s of the switches turnd on. After one or two minutes the first switch had no traffic on the ports, but the second one worked normal. The status led was yellow. I read, that the status led is yellow, when it´s one-side connected... but i have not found any explanation how to solve this problem. I hope you can help me. I would be happy, if you could write one (or more) suggestions. Thank´s and Greetings from Tyrol
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Jul 27, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
20484
Points
20
Found this on 3Com website: The SuperStack 3 Switch 3870 family (3870-24 and 3870-48) can stack up to 8 units high. Stacks can be formed with any combination of 24-port and 48-port units, with a maximum of 384 (8 x 48) front panel ports supported. When connected together, a stack of units is managed as a single entity. All units in the stack need to run the same release of the operational version code (firmware). When units are stacked together, they operate in a master-slave relationship. One unit acts as a Master and the other units act as slaves. When looking at a stack of units, the master can be identified by looking at the Stack Master LED on the left side of the switch. The Stack Master LED is green for the Master. If the unit numbers are out of sync, go to the CLI command that allows users to re-number their units- system / control / renumber. This will re-number the units in the stack. It will take about a minute or two. The master is the only unit that has a visible command line interface (CLI) when a console cable is connected to it. If you connect the console cable to a slave unit, you will not see the CLI menu, but instead see slave status messages being displayed. The Master unit may not be unit 1. http://knowledgebase.3com.com/consumer/esupport.asp?id=GUIDbfa9caa4%5F138f%5F4681%5Fbaaf%5F5c99ec5b7ff4&resource=&number=0&isExternal=0&nShowFacts=&nShowCause=&nShowChange=&nShowAddInfo=&activepage=statement.asp&bForceMatch=True&strCurrentSymptom=3C17462&searchtype=normal&searchclass=&bnewsession=false&selecttype=match
How do I stack my euro tech dryer?
When stacking your washer and dryer, your dryer should always be placed on top of your washer. To protect your dryer from damage and to make it easier to move,place a piece of cardboard on the floor and tilt your dryer on its back onto the cardboard.
What is the difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL?
The main difference between WS-C2960X-24TS-L and WS-C2960X-24TS-LL as below:
WS-C2960X-24TS-L 4 SFP Uplink, WS-C2960X-24TS-LL 2 SFP Uplink.
WS-C2960X-24TS-L supports FlexStack-Plus stacking while WS-C2960X-24TS-L does not.
WS-C2960X-24TS-L with LAN Base feature set, WS-C2960X-24TS-LL with Lan Lite feature set.
I hope it can help you.
WS C2960X 24TS
1helpful
I have a number of Netgear FSM726S and FSM750S switches. During an office move some of the stacking cables went missing and I am trying to source replacements
Found some on amazon they look like the correct ones.
http://www.amazon.co.uk/NETGEAR-ProSafe-Stacking-cable-SFP/dp/B0047IMKCW
Thanks
I am concerned about srewing the stacking kit to
Maybe, depends on the age of the washer; you should be able to use the screws that come with the stacking kit.... which screw into existing holes in the washer.
How can i stack 3com 4900sx switches? Do i need accessories to do this?
If you would like mulitple switchs its as simple as running a patch cable from you port in the switch to one port in the other switch.
Other user: There is no such thing as dhcp in a switch that is done by higher level networking leveling like routers
2helpful
2answers
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
4helpful
2answers
Stacking Instructions
You will need a stacking kit 5303937141 to stack them, Feel free to ask for any more advice.
Top 3Com Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
