SOURCE: How can I keep my Tiger Shark from sticking to the main drains.
Decrease suction on main drain and increase suction to cleaner.
SOURCE: My Tiger Shark is on
Get your dealer or the repair center to issue a call tag to get it back and fix it right this time. If they are a reputable repair center they will cover the return freight charge and re-diagnose the problem. It may need additional repairs than what was originally quoted and those may have an additional cost but they should at least cover the return freight to get it back to see what is wrong.
John
SOURCE: i have a tiger shark one and half years old. it
The motor pack is having trouble and will need to be replaced (most likely). For help finding a service center that can perform the inspection and repairs check Hayward's site at http://www.haywardnet.com/locator/ and fill in the information requested. Be sure to select product repair or service and robotic cleaners to limit the response to those able to fix these cleaners. We are in S.E. Michigan and are one of the centers for Tiger Shark cleaners.
John
SOURCE: my tiger shark pool cleaner
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
SOURCE: My tiger shark does not
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
