I have added backed up contact persons from a SIM card but I can't search for them as the Nokia 101 I am using does not seem to have hebrew installed on it. Is there any possibility to go around that (Other wise I have to manually locate the numbers amongst 399 contact persons) Thanks in advance
SOURCE: Saving Bluetooth Messages in Memory Card in Nokia N73
go to message settings-- other settings---change memory in use to memory card by options... welcome-----. [email protected]
SOURCE: want to copy all contacts to sim card
To copy a phone, fax, or pager number from contacts to your SIM card, scroll to
the contact you want to copy, and select Options > Copy > To SIM directory.
SOURCE: change from nokia n95 to new mobile want to save contacts to sim
You'll probably find they're already on the sim, if not here's how to copy them over.
Open contacts, options, SIM contacts, SIM directory; you should see all contacts that are on your sim. If there's none there, select back which will take you to your contacts; choose options again, scroll to mark/unmark press select then mark all, all contacts should now have a tick beside then. Then options again, copy & lastly to sim directory.
SOURCE: nokia n70 start up sim card not valid
check ur phone IMEI no. (*#06#) if this ??????????????4 then go to nokia care and reinstall IMEI no. OK
SOURCE: I have a Nokia E71 and using SIM from my old
open "address book", then press "option"scroll down to "SIM contacts" and press the right-navigation key and select "SIM Directory"
It will display contacts on your SIM card. To copy contacts from SIM to phone memory. Select "Options" then scroll down to "Mark/Unmark" press right-navigation key and select "Mark All" then select "Options" again and then select "Copy to Contacts"
That will copy your contacts from SIM to Phone directory.
