Where are fuse boxes?
Where is the relay a/c condenser fan location?off 2003 mdx acura?
On this website, you find fuse box diagram and description for Acura MDX (2003)
Acura MDX 2003 fuse box diagram Auto Genius
SOURCE: Where is the fuse for the tail lights.
the fuse is in the passengers under dash fuse box which is behind the kick pannel ..under the glove box on the door side and you should see a little access door to get at the fuse box...hope this helps
SOURCE: acura mdx 2005
30000 miles.the owners manual will tell you exactly.most honda are 48000 km,exception is the cvt type transmission which there is no service done.
SOURCE: will steering angle sensor trigger vsa
the steering angle sensor is used as one of many inputs on honda's vehicle stability assist system. so in short yes. hope this helps
SOURCE: i have a 2004 acura mdx and the book says i have 5
1 under left side of the dash
2 right side of engine compartment
3 behind under hood fuse/relay box
4 behind right kick panel
there is an auxiliary fuse box next to the battery
Testimonial: "Aha. That fuse box by the psgr. kick plate was the answer. Thanks so much..."
SOURCE: 2006 acura mdx. battery completely dead now I
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
