The unit was in use, opened door adjusted food, closed door, then loud buzzing sound, turn table stopped, still running and stop/cancel button on keyboard won't work while in process. Only way to shut down is to unplug or keep door open. When plugged back in, allows the resetting of clock, but once door is closed it starts buzzing and running again. Will not cease via control buttons. Please advise and thank you for your help.
It is one of two things, a defective door switch, or the keypad control board has failed.
Testimonial: "Yes, it was honest and help me make a decision of repairing or replacing. Thank you so much."
SOURCE: KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
SOURCE: Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
SOURCE: GE JE1860 microwave won't turn off sometimes
You probably have a sticking relay on the control board.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have full details of our service, plus *critical* safety, disassembly, and troubleshooting info at our site.
You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
It is possible that you might have a bad door switch but I don't think so. In case you or a friend want to check that first, here are some links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: constantly runs but does not heat
The circuit board is faulty. It should be covered under the warranty. Call GE or the place of purchase.
SOURCE: The microwave just stopped working
The problem is the magnetron. This is the part of the microwave that heats the food. partselect,com likely has your part with a diagram and great prices.
When I press the stop button it beeps, but doesn't stop the unit. When I press the start button there is no reaction or beep. But the other controls on the panel when push engage in the beeping sound. Could it be a relay switch on the start button causing it to stay engaged? How do you fixed a failed control board and is it an expensive repair? I so appreciate your guidance. Are any of these repairs something I can do myself?
