I have a 97 buick regal gs and it won't start but all the lights comes on & the horn works. When I turn the key to crank the car all the lights cuts off & it don't make no noise, everything shuts down. Can it be a fuse that is stopping it from starting?
SOURCE: 1999 Buick regal Security light on. Won't start.
I had the same problem with my 95 Lesabre. The owners manual says to take the key out, and wait 3 minutes(until the light goes off). It should fire right up.
SOURCE: 1999 Buick Regal GS key problem.Can't get key out of ignition
its the button on the shifter, sometimes it doesnt contact the key unlock solenoid. all you have to do is turn the key to on position, (not start) press brake, and push the button on the shifter, youll hear a click in the ignition. then key will come out
SOURCE: Buick Regal dying
You have a problem in the fuel pump relay circuit for sure then. I'm betting the relay, but it could be that dropping resistor.
the answer here is the forward clutch pack is worn out, in order to replace this umust overhaul the trans.
SOURCE: 98 buick lesabre limited, horn started honking
sounds like you have a short in the horn wiring or a bad ground wire these grounds are mostly located under the engine compartment near the back wall whitch is called the fire wall or beside the fenders
